6 Replies Latest reply on Feb 5, 2013 12:56 AM by Prasanna Kalidass
    Check Ballooning is done for each BOM item
    Prasanna Kalidass
      Is there any api/macro to check whether the Item in BOM is Ballooned or not??
      Above shows, Row 2 and 3 are ballooned where as Row 4 and 5 are not ballooned. Is there a way to find it using api/macro.
      Please help.
        • Re: Check Ballooning is done for each BOM item
          Glenn Schroeder
          Since the little balloon icons with the 1 in them already indicate which components are ballooned I don't understand why you need a macro, but if you still want one you might get more responses if you move this discussion to the API section.
            Keith Rice
            Prasanna,
            I am not aware of such a macro. I believe you would need to traverse all balloons in a particular view and use IAnnotation::GetAttachedEntities3 in order to find out what components they are attached to. I actually have a free video tutorial  that walks through a very similar macro. It demonstrates how to write a macro that deletes balloons attached to fasteners. I think you would find it very helpful, should you pursue writing this macro.
            Keith
            Video Tutorials for the SolidWorks API
                Prasanna Kalidass
                Thanks Keith. Hope there is no method in BomAnnotation, BomTable, BomFeature or TableAnnotation.
                  Prasanna Kalidass
                  Dim BOMTable1 As BomTableAnnotation
                          swDrwDoc.ActivateView(View.GetName2)
                          bRet = swModel.Extension.SelectByID2(ViewName, "DRAWINGVIEW", 0, 0, 0, False, 0, Nothing, 0)
                          BOMTable1 = View.InsertBomTable2(False, 0.0, 0.0, swBOMConfigurationAnchorType_e.swBOMConfigurationAnchor_TopLeft, swBomType_e.swBomType_PartsOnly, Config, "")
                          Dim SelecMgr As SelectionMgr
                          SelecMgr = swModel.SelectionManager
                          Dim View5 As View
                          Dim Ann5 As Object
                          View5 = SelecMgr.GetSelectedObject5(1)
                          Ann5 = View5.GetAnnotations
                          Dim bret5 As Boolean
                          For i1 = 1 To nNumRow1 - 1
                              BOMTable1.GetComponentsCount2(i1, Config, ItemNumber1, PartNumber1)
                              Try
                                  Dim swAnn As Annotation
                                  Dim swNote As Note
                                  Dim Dis As String = Nothing
                                  For I As Integer = 0 To UBound(Ann5)
                                      Dis = Nothing
                                      bret5 = False
                                      swAnn = Ann5(I)
                                      If swAnn.GetType = swAnnotationType_e.swNote Then
                                          swAnn.Select3(False, Nothing)
                                          swNote = SelecMgr.GetSelectedObject5(1)
                                          If swNote.IsBomBalloon Then
                                              Dis = swNote.GetText
                                              If Dis IsNot Nothing Then
                                                  If Dis = ItemNumber1 Then
                                                      ''Balloon is available
                                                      bret5 = True
                                                      Exit For
                                  Next I
                                  If bret5 = True Then
                                  Else
                                      Table1.Text(i1, 5) = "Part Not Ballooned"
                              Catch ex As Exception
                              Finally
                              End Try
                          Next i1
                  Thanks Keith.. I have compared the Baloon Text with BOM Item No to sort it out.
                  the Code might not be in Order. Thanks
