3 Replies Latest reply on Jan 30, 2013 4:35 AM by Yong Ning
    Add the File properties to every part in the assembly without opening every part one by one
    Vincent Li
      Adding the property to every part of assembly,
      currently, I know the below  behavior called by API,
      In the assembly mode, we can open a part ,then go to file> property > add property >save part >close part , then back to the assembly, and keep on doing the same thing to next part.
      But it seems low performance if handle a large assmebly.
      and I want to do it without opening every part one by one.
      thanks
      regards
      Vincent
        • Re: Add the File properties to every part in the assembly without opening every part one by one
          Keith Rice
          Vincent,
          This code will add a custom property called "Test" to every part in an assembly:
          Dim vComps As Variant
          Dim swCompModel As SldWorks.ModelDoc2
          Dim swCustPropMgr As SldWorks.CustomPropertyManager
          Dim i As Integer
              Set swModel = swApp.ActiveDoc
              Set swAssy = swModel
              vComps = swAssy.GetComponents(False)
              For i = 0 To UBound(vComps)
                  Set swComp = vComps(i)
                  Set swCompModel = swComp.GetModelDoc2
                  Set swCustPropMgr = swCompModel.Extension.CustomPropertyManager(Empty)
                  swCustPropMgr.Add2 "Test", swCustomInfoText, "This is a test"
                  'swCompModel.Save3 swSaveAsOptions_Silent, Empty, Empty
              Next i
          If you want the changes to the part to be saved, then un-comment the last line contained in the For - Next loop.
          Keith
          Video Tutorials for the SolidWorks API
              Yong Ning
              Thanks code.
              Dim SwApp As SldWorks.SldWorks
              Dim SwAss As SldWorks.AssemblyDoc
              Dim SwModel As ModelDoc2
              Sub ll()
                Set SwApp = Application.SldWorks
                Set SwModel = SwApp.ActiveDoc
                Set SwAss = SwModel
                Debug.Print SwAss.GetPathName
                With SwAss
                  Debug.Print .GetComponentCount(True)
                  vComps = .GetComponents(False)
                End With
                  Set swCompModel = swComp.GetModelDoc  ' swComp.GetModelDoc2
                  Debug.Print swCompModel.GetPathName
                  tmp = cc(swCompModel)
              Next i
              With swCompModel
              End With
              Function cc(SwModel As ModelDoc2)
                  Dim vConfigNameArr                  As Variant
                  Dim vConfigName                     As Variant
                  Dim vCustInfoNameArr                As Variant
                  Dim vCustInfoName                   As Variant
                  Dim temp
                  Dim bRet                            As Boolean
                  Debug.Print "File = " & SwModel.GetPathName
                  vConfigNameArr = SwModel.GetConfigurationNames
                  ' Is empty if a drawing becasue configurations not supported on drawings
                  If IsEmpty(vConfigNameArr) Then
                      ReDim vConfigNameArr(0)
                      vConfigNameArr(0) = ""
                  Else
                      ' Add a blank string for the nonconfiguration-specific custom properties
                      ReDim Preserve vConfigNameArr(UBound(vConfigNameArr) + 1)
                  For Each vConfigName In vConfigNameArr
                      Debug.Print "  " & vConfigName
                      vCustInfoNameArr = SwModel.GetCustomInfoNames2(vConfigName)
                      If Not IsEmpty(vCustInfoNameArr) Then
                          For Each vCustInfoName In vCustInfoNameArr
                              Debug.Print "    " & vCustInfoName
                              Debug.Print "      Type     = " & SwModel.GetCustomInfoType3(vConfigName, vCustInfoName)
                              Debug.Print "      Value    = " & SwModel.GetCustomInfoValue(vConfigName, vCustInfoName)
                              Debug.Print "      Text     = " & SwModel.CustomInfo2(vConfigName, vCustInfoName)
                              Debug.Print vConfigName
                              'temp = SwModel.DeleteCustomInfo2(vConfigName, vCustInfoName)
                          Next
                      Debug.Print "  ---------------------------"
                  Next
              End Function
              Result is
              D:\Backup\我的文档\Draw\Assem1.SLDASM
              1
              D:\Backup\我的文档\Draw\Part1.SLDPRT
              File = D:\Backup\我的文档\Draw\Part1.SLDPRT
                Default
                  质量
                    Type     = 30
                    Value    = 975.08
                    Text     = "SW-Mass@Part1.SLDPRT"
              Sub ll()
                Set SwAss = SwModel
                With SwAss
                End With
                  Arr = BaseCustInfo(swCompModel)
                  tmp = AddCustomInfo(swCompModel, Arr)
                  Debug.Print
              Next i
              With swCompModel
              End With
              Function AddCustomInfo(SwPart, Arr)
                '添加文件的自定义属性
                 With SwPart
                   For ii = 0 To UBound(Arr)
                         .AddCustomInfo3 "", Arr(ii, 0), 30, Arr(ii, 1)
                         .CustomInfo2("", Arr(ii, 0)) = Arr(ii, 1)
                   Next ii
                 End With
              End Function
              Function BaseCustInfo(SwModel)
                Dim FileName
                  FileName = SwModel.GetPathName
                  nn = InStrRev(FileName, "\")
                  FileName = Right(FileName, Len(FileName) - nn)
                Dim Arr(3, 1)
                  Arr(0, 0) = "质量":  Arr(0, 1) = "SW-Mass":
                  Arr(1, 0) = "材料 ":  Arr(1, 1) = "SW-Material":
                  Arr(2, 0) = "密度":  Arr(2, 1) = "SW-Density":
                  Arr(3, 0) = "体积":  Arr(3, 1) = "SW-Volume":
                For ii = 0 To 3
                  Arr(ii, 1) = """" & Arr(ii, 1) & "@" & FileName & """"
                Next ii
                BaseCustInfo = Arr
              End Function
              Function ChangeCustomInfo(SwPart, Arr)
                '更改文件的自定义属性
                'Debug.Print SwPart.GetPathName
                 With SwPart
                   Next ii
                 End With
              End Function
              Function DeleteCustInfo(SwPart)
                '清空自定义属性的内容
                  Dim bRet                            As Boolean
                  With SwPart
                    vConfigNameArr = .GetConfigurationNames
                    Else
                      vCustInfoNameArr = .GetCustomInfoNames2(vConfigName)
                              'Debug.Print "    " & vCustInfoName
                              bRet = SwPart.DeleteCustomInfo2(vConfigName, vCustInfoName)
                          Next
                    Next
                  End With
              End Function
                Dim FileName
                Dim Arr(3, 1)
                For ii = 0 To 3
                Next ii
                BaseCustInfo = Arr
              End Function
