'insufficient data' error when viewing results
Discussion created by Guest on Sep 11, 2006
Has anyone else experienced this goofy 'bug'??
I have two users on 64-bit Solidworks/Cosmos that can-not use a results folder twice in a row when running studies. If they have a brand-new/clean results folder set up (study>properties>results folder) then everything works fine and they get all their results. (displacement and stress etc.) but when they go and run that study again. Or run a new study that then uses the same results folder to store stuff, it will show only the displacement results, and gives the error "insufficient data in results folder" when you try to display the Stress plot.
However, when I run test studies on my own personal machine (which is identical to theirs) it all works fine.
Thanks for any ideas!!
-Tim G
