I have Enterprise PDM 2012 SP3 running on a test W2K8 VM and about to go live on a new server with EPDM 2013 SP1. I will be installing SQL Server 2008 and EPDM 2013 SP1 from scratch on the new server. I only have one EPDM client installed for testing purposes.
The vault on the test server is called PDM2012 and has valid data that I want to transfer to the new server as a new vault AND I want the new vault to have a different name (I want to drop the '2012' part of the name). I have read elsewhere that renaming the vault is not possible, but the vault will be going on to a new server.
Is there a way of doing this?
Wayne,
It's all described in the Installation Guide, which you can download from the "Admin Guides" link, under "References", in the customer portal.
