3 Replies Latest reply on Jan 29, 2013 5:59 PM by Artem Taturevych
    Align Grid/Origin
    Yateen Shembade
      Is there a macro I can use for this.
      I end up using  this command very oftne while designing.
      I tried to record it but it doesn't work.
      or can any one tell me what will be the API command for it?
        • Re: Align Grid/Origin
          Artem Taturevych
          Can you please clarify what are you looking for - I'm a bit confused. Sample snapshot/video would be the best.
          __________________________
          Regards,
          Artem Taturevych
          Application Engineer at Intercad
          http://intercad.com.au/
          Tel: +61 2 9454 4444
              Yateen Shembade
              I am looking for macro solution for the following command.
              I use this command often when I am switching planes for the holewizard features to align the origin of the feater with the origin of the part.
                  Artem Taturevych
                  Thanks for the clarifications. Now it is clear.
                  Unfortunately there is no direct API method for this. However this functionality may be achieved with the entities rotate/translate functions.
                  I have created the macro which can set the sketch origin and x axes aligned with the selected entities. Note, I have improved the original Align function. Now you can select linear edges, sketch lines, vertices and sketch points both in the active sketch or in another sketch. The origin will be aligned with selected sketch point/vertex and the x-axes with selected edge/sketch line.
                  Note. You can create a button for this macro and assign the hot key. Use 'main' function as entry point.
                  Regards,
                  Artem Taturevych
