I am new to surfacing and have made a hood for a car I am building. In the past I've made simpler hoods from single lofts, and made proper molds for CNC'ing foam, but am finding my newest hood difficult. I am looking to exract the piece of the large extrude below the hood. I perform inhouse ABS vacuum forming over the machined foam block, but am unable to isolate a block from the model. I have tried using the mold command split with no luck. Also thickening the surface seems beyond me. I have attached the file in hopes that someone with more experience can help me.
Hi
you need to use cut with surface but all the blue lines that you see on the surface(not on the edges) means that you have gaps between surfaces. you need to fix them and then use cut with surface or extrude up to surface.
hope this help
