1 Reply Latest reply on Jan 26, 2013 7:08 PM by Artem Taturevych
    How to obtain sketh name?
    Yong Ning
      Set oSketch = .GetActiveSketch2
      but don't obtain Sketch name?
      the code is
      Sub ll1()
        Dim SwApp As SldWorks.SldWorks
        Dim SwModel As ModelDoc2
        Dim oFeat As Feature
        Set SwApp = Application.SldWorks
        Set SwModel = SwApp.ActiveDoc
        Dim oSketch As Sketch
        Dim SwSelMgr As SelectionMgr
        Dim vPtArr, SwSkethPoint As SketchPoint
        With SwModel
          Set SwSelMgr = .SelectionManager
          vPtArr = oSketch.GetSketchPoints
               For Each Pt In vPtArr
                 Set SwSkethPoint = Pt
                 With SwSkethPoint
                    Debug.Print .Type
                   .Select4 False, Nothing
                 End With
               Next
        End With
      http://help.solidworks.com/2010/English/api/sldworksapi/Get_Hole_Series_Information_Example_VB.htm
        • Re: How to obtain sketh name?
          Artem Taturevych
          Check lines in red:
            With SwModel
              Set oFeat = oSketch
              Dim sketchName As String
              sketchName = oFeat.Name
              Debug.Print sketchName
                     With SwSkethPoint
                        Debug.Print .Type
                     End With
                   Next
            End With
          __________________________
          Regards,
          Artem Taturevych
          Application Engineer at Intercad
          http://intercad.com.au/
          Tel: +61 2 9454 4444
