When I apply a material in Solidworks (2011 SP2.0) and open the Photoview Preview Window, the color appears slightly darker than should be. When opening the feature manager of the applied material, you can see the color in the Preview Window update to it's correct value. When closing Photoview and reopening the Preview Window, colour is darkened again.
material white medium gloss plastic applied, then opened Preview Window. Material shows too dark:
On reopening material, it shows up correctly (brighter) in Preview Window:
This happens with all materials also in assemblies, so I have to launch the Photoview Preview Window and open every applied material one by one to update for a proper rendering result.
Most materials show a shade darker when not updated. Glass gives worse results. When I for instance apply a green glass and customize the color to blue, the glass still shows green in Photoview, unless I open the glass material again with Preview Window active.
Is this a bug in Photoview 2011? Please help.
Here's some screenshots of the problem with green glass applied:
Then color customised to blue:
Accept, close and reopen photoview Preview Window:
Voila! Inconsistent material rendering in Photoview.
This really is impossible to work with when applying more materials to a model or assembly. Hope anyone has got a solution for this?
By the way, I did this post from my laptop with SW2011 SP1.0, original post is from my desktop with SW2011 SP2.0. Both have the same problem.
Any help is very welcome!
