In my animation I have a part that need to revolve more than
360 deg.
So I added the 360 deg and next to it added the 0 deg. in the
timeline (using the smallest increment possible). I set the 0 deg
to snap so it should be seemless. But I always get a small pause in
my final recording when it passes through this point. has anyone
seen something similar, ond/or does anyone have a solution to this?
Hi Dan,
what kind of interpolation mode do you use for the key
properties?
Maybe a change to 'Snap' will help.
______________________
Kind Regards,
Ralf Tide
CSWP
www.tidecad.de
So I added the 360 deg and next to it added the 0 deg. in the timeline (using the smallest increment possible). I set the 0 deg to snap so it should be seemless. But I always get a small pause in my final recording when it passes through this point. has anyone seen something similar, ond/or does anyone have a solution to this?
Dan
what kind of interpolation mode do you use for the key properties?
Kind Regards,
Ralf Tide
CSWP
www.tidecad.de
