1 Reply Latest reply: Jan 25, 2013 9:13 AM by Yong Ning
    How to use the Table Driven Patterns with API?
    Yong Ning
      the X-Y coordinates of a feature pattern, and apply them to a new part
      Help me, use API method, run table driven pattern function.
      Thanks.
        • Re: How to use the Table Driven Patterns with API?
          Yong Ning
          http://help.solidworks.com/2013/English/api/sldworksapi/get_table-driven_pattern_properties_example_vb.htm
          'This example shows how to get the properties of a table-driven pattern.
          But don't change table driven pattern?
          Help  me , How to change follow code ?
          'Get Table-driven Pattern Properties Example (VB)
          Option Explicit
          ' TablePatternFeatureData::GetReferencePointType
          '        0 = closed curve
          '        1 = sketch point
          '        2 = vertex
          Sub ProcessCoordSys _
          ( _
              swApp As SldWorks.SldWorks, _
              swModel As SldWorks.ModelDoc2, _
              swCoordSys As SldWorks.Feature _
              Dim swDocExt                As SldWorks.ModelDocExtension
              Dim swXform                 As SldWorks.MathTransform
              Set swDocExt = swModel.Extension
              Set swXform = swDocExt.GetCoordinateSystemTransformByName(swCoordSys.Name)
              Debug.Print "  " & swCoordSys.Name
              Debug.Print "    Origin = (" & -1# * swXform.ArrayData(9) * 1000# & ", " & -1# * swXform.ArrayData(10) * 1000# & ", " & -1# * swXform.ArrayData(11) * 1000# & ") mm"
              Debug.Print "    Rot1   = (" & swXform.ArrayData(0) & ", " & swXform.ArrayData(1) & ", " & swXform.ArrayData(2) & ")"
              Debug.Print "    Rot2   = (" & swXform.ArrayData(3) & ", " & swXform.ArrayData(4) & ", " & swXform.ArrayData(5) & ")"
              Debug.Print "    Rot3   = (" & swXform.ArrayData(6) & ", " & swXform.ArrayData(7) & ", " & swXform.ArrayData(8) & ")"
              Debug.Print "    Trans  = (" & swXform.ArrayData(9) * 1000# & ", " & swXform.ArrayData(10) * 1000# & ", " & swXform.ArrayData(11) * 1000# & ") mm"
              Debug.Print "    Scale  = " & swXform.ArrayData(12)
              Dim swApp                   As SldWorks.SldWorks
              Dim swModel                 As SldWorks.ModelDoc
              Dim swSelMgr                As SldWorks.SelectionMgr
              Dim swFeat                  As SldWorks.Feature
              Dim swTableFeatData         As SldWorks.TablePatternFeatureData
              Dim swRefPt                 As SldWorks.Vertex
              Dim swCoordSys              As SldWorks.Feature 'Object
              Dim vBasePt                 As Variant
              Dim vFace                   As Variant
              Dim vFeat                   As Variant
              Dim vPt                     As Variant
              Dim nPtType                 As Long
              Dim vRefPtParam             As Variant
              Dim bRet                    As Boolean
              Dim i                       As Long
              Set swModel = swApp.ActiveDoc
              Set swFeat = swSelMgr.GetSelectedObject5(1)
              Set swTableFeatData = swFeat.GetDefinition
              ' Roll back to get the reference point
              bRet = swTableFeatData.AccessSelections(swModel, Nothing): Debug.Assert bRet
              Set swRefPt = swTableFeatData.ReferencePoint
              Set swCoordSys = swTableFeatData.CoordinateSystem
              vBasePt = swTableFeatData.GetBasePoint
              vFace = swTableFeatData.PatternFaceArray
              vFeat = swTableFeatData.PatternFeatureArray
              vPt = swTableFeatData.PointArray
              Debug.Print swFeat.Name
              Debug.Print "  Coord sys            = " & swCoordSys.Name
              ProcessCoordSys swApp, swModel, swCoordSys
              Debug.Print "  FaceCount            = " & swTableFeatData.GetPatternFaceCount
              Debug.Print "  FeatureCount         = " & swTableFeatData.GetPatternFeatureCount
              Debug.Print "  PointCount           = " & swTableFeatData.GetPointCount
              Debug.Print "  ReferencePointType   = " & swTableFeatData.GetReferencePointType
              Debug.Print "  BasePt               = (" & vBasePt(0) * 1000# & ", " & vBasePt(1) * 1000# & ", " & vBasePt(2) * 1000# & ") mm"
              Debug.Print "  GeometryPattern      = " & swTableFeatData.GeometryPattern
              Debug.Print "  UseCentroid          = " & swTableFeatData.UseCentroid
              If Not swRefPt Is Nothing Then
                  ' Is NULL if centroid used
                  vRefPtParam = swRefPt.GetPoint
                  Debug.Print "  RefPt                = (" & vRefPtParam(0) * 1000# & ", " & vRefPtParam(1) * 1000# & ", " & vRefPtParam(2) * 1000# & ") mm"
              ' Roll forward
              swTableFeatData.ReleaseSelectionAccess
          http://help.solidworks.com/2013/English/api/sldworksapi/Get_Points_of_Repeating_Elements_in_Table-driven_Pattern_Example_VB.htm
