Is there a way to make this all one Lofted Sheet Metal part. The end result will actually be a 2" high tab along the flat edge of the of this part. We will cut on our flat laser this part with tabs then create small round flats for the ends. This will result in less welding and a nicer part. Is it possibe to use 3 sketches in a Lofted Sheet Metal part? Another solution?
We solve such things as in the appendix
