2 Replies Latest reply on Nov 15, 2015 4:20 AM by Yong Ning
    how to hide origin in assembly?
    Yong Ning
      'Select Origin of Assembly Component Example (VB)
      'This example shows how to get the origin of an assembly component.
      ' Preconditions:
      '       (1) Assembly document is open.
      '       (2) Assembly is fully resolved.
      '       (3) A component is selected.
      ' Postconditions: Origin of the selected component is selected.
      Option Explicit
          Dim swApp                       As SldWorks.SldWorks
          Dim swModel                     As SldWorks.ModelDoc2
          Dim swSelMgr                    As SldWorks.SelectionMgr
          Dim swSelComp                   As SldWorks.Component2
          Dim swCompModel                 As SldWorks.ModelDoc2
          Dim swFeat                      As SldWorks.Feature
          Dim bRet                        As Boolean
          Dim SwPt As MathPoint
          Set swModel = swApp.ActiveDoc
          Set swSelComp = swSelMgr.GetSelectedObjectsComponent(1)
          Set swCompModel = swSelComp.GetModelDoc
          swModel.ClearSelection2 True
          Set swFeat = swSelComp.FirstFeature
          Do While Not swFeat Is Nothing
              If "OriginProfileFeature" = swFeat.GetTypeName Then
                  bRet = swFeat.Select2(False, 0): Debug.Assert bRet
                  Exit Do
              Set swFeat = swFeat.GetNextFeature
          Loop
      Help me
      How to hide origin →  Origin of the selected component is selected
        • Re: how to hide origin in assembly?
          Artem Taturevych
                      swModel.BlankSketch 'Hide origin
                      'swModel.UnblankSketch 'Show origin
                      Exit Do
          _______
          ___________________
          Regards,
          Artem Taturevych
          Application Engineer at Intercad
          http://intercad.com.au/
          Tel: +61 2 9454 4444
              Yong Ning
              Thank your tips
              the code is
              Option Explicit
                  Dim bRet                        As Boolean
                          swModel.BlankSketch
                          Exit Do
                  Loop
              Function HideAxisAndOrigin(SwModel As ModelDoc2)
                  Dim SwFeat As Feature
                     Set SwFeat = SwModel.FirstFeature
                     Do While Not SwFeat Is Nothing
                         If SwFeat.GetTypeName = "RefAxis" Then
                             SwFeat.Select True
                             SwModel.BlankRefGeom
                         If SwFeat.GetTypeName = "OriginProfileFeature" Then
                             SwFeat.Select2 False, 0
                         Set SwFeat = SwFeat.GetNextFeature
                     Loop
              End Function
