I have been using the electrical routing feature for some time now. I recently installed SW 2012 and it appears a few things have changed. I have my own wire size data file (xml file). There is now a wizard in SW to aid in editing or creating files. Whe I went into this file to edit my xml file it would only let me access the default wire file tha comes with SW. How can i make SW allow me to access the other xml files?
Thanks...
I solved it.......there is another tab within the wizard where you change the file references.
This tab is labeled "Routing File Location and Settings".
