I am simulating a 5 plies isotropic composite shell. The stress calxulations seems correct. But for FOS I am getting the following error: "All materials do not have sufficient stress limits to calculate the requested results....'. Couls someone help with the reason for this massage?
Stress result requires density, poisson's ratio and modulus of elasticity. To create a FOS plot you must also have ultimate and yield stress limits. Check each material properties and make sure all of these fields are filled in. If some are missing in Solidworks materials then you will need to create custom materials.
