I have a design table I have set up, based on a sketch. I would lke to bring that sketch + DT into several other parts (similar to inserting a block) and then apply a feature to it. Essentially an interactice block.
It's probably something simple that I've overlooked, but I'm relativily new to DT and configurations.
I've searched, and if it's out there, I'm obviously searching in the wrong area!
Thanks.
You probably found it by now but you can save your design table to an external file with link to file option enabled and then save that file under any other name (as long as it is in the same folder) and they will all be linked to that external design table excel file.
This has huge benefits, but unfortunately for what I was planning to use it for it also has a significant negative and that negative is the fact that you won't be able to drive custom properties (description, material, finish etc.) using that table, unless you have multiple redundant configurations in each of those parts which will be quite messy.
