2 Replies Latest reply on Jan 21, 2013 8:38 AM by D. L
    ReplaceReference Method (ISwDMDocument) not work correctly
    D. L
      good morning everyone,
      i have a problem with the replace function of the document manager api.
      i use the the following code for replacing references:
        public static void SetReferences(SWDocument document)
                  _factory =
                      (SwDMClassFactory)
                      Activator.CreateInstance(Type.GetTypeFromProgID("SwDocumentMgr.SwDMClassFactory"));
                  if (_factory != null)
                      _application =
                          (ISwDMApplication3)_factory.GetApplication("42804944AF393A4E8DA9890ABBC6F7D0D74390EEE2C65689");
                  if (_factory == null || _application == null)
                      return;
                      _document = (ISwDMDocument13)_application.GetDocument(document.Destination, _type, false, out _errors);
                  if (_document == null)
                      return;
                  _application.GetSearchOptionObject().ClearAllSearchPaths();
                  var r = _document.GetAllExternalReferences(_application.GetSearchOptionObject());
                  if (r == null)
                      foreach (var result in document.Children)
                          _document.ReplaceReference(result.Source, result.Destination);
                  else
                      foreach (var result in (new List<string>(r)))
                          var find = document.Children.Find(x => x.Source.ToLower() == result.ToLower() || x.Destination.ToLower() == result.ToLower());
                          if (find == null)
                              continue;
                          _document.ReplaceReference(result, find.Destination);
                  _document.Save();
                  _factory = null;
                  _application = null;
                  _document = null;
      when i tried to replace a reference on a sw part then it works correctly. but when i try to replace a din part reference it not work.
      ..\SolidWorks Data\browser\DIN\bolts and screws\socket set screw cone point_din.sldprt (original reference)
      should replace to
      ..\Temp\temp_socket set screw cone point_din
      it is the same part but with different filename.
      can anyone help me?
      thanks
      daniel
