1 Reply Latest reply on Jan 21, 2013 3:19 AM by Yong Ning
    How to set oneself Material ?
    Yong Ning
      Set Material Property Name Example (VB)
      This example shows how to set a part's material property name.
      http://help.solidworks.com/2012/English/api/sldworksapi/set_material_property_name_example_vb.htm
      'Set Material Property Name Example (VB)
      'This example shows how to set a part's material property name.
      ' Preconditions: Part document is open.
      ' Postconditions: Model and part material property name changed to Alloy Steel.
      'Option Explicit
      Sub main2()
          Dim swApp                       As SldWorks.SldWorks
          Dim swModel                     As SldWorks.ModelDoc2
          Dim swPart                      As SldWorks.PartDoc
          Dim i                           As Long
          Dim bRet                        As Boolean
          Set swModel = swApp.ActiveDoc
          Set swPart = swModel
          Debug.Print "File = " & swModel.GetPathName
          Debug.Print "  Old model material   = " & swModel.MaterialIdName
          Debug.Print "  Old part  material   = " & swPart.MaterialIdName
          ' Apply new material. This operation overwrites the information in
          ' ModelDoc2::MaterialIdName and PartDoc::MaterialIdName.
          swPart.SetMaterialPropertyName "SolidWorks Materials.sldmat", "Alloy Steel"
          Debug.Print "  New model material   = " & swModel.MaterialIdName
          Debug.Print "  New part  material   = " & swPart.MaterialIdName
      Help me,
      How to change sldmat, set oneselft material.
      Thanks .
      http://help.solidworks.com/2012/English/api/sldworksapi/get_and_set_material_visual_properties_example_vb.htm
        • Re: How to set oneself Material ?
          Yong Ning
          Sub Main1()
            Dim sMatName As String
            Dim sMatDB As String
            Dim bRet As Boolean
            sMatName = swPart.GetMaterialPropertyName2("Default", sMatDB)
            Debug.Print " Material = " & sMatName & " (" & sMatDB & ")"
