4 Replies Latest reply on Jan 20, 2013 6:07 AM by Yong Ning
    what POSGROUP in mate?
    Yong Ning
      http://help.solidworks.com/2012/English/api/sldworksapi/Get_Mate_Reference_Properties_Example_VB.htm
      Get Mate Reference Properties Example (VBA)
      Don't understand what “POSGROUP” means.
      use → boolstatus = swModelDocExt.SelectByID2("Default-<1>", "POSGROUP", 0, 0, 0, False, 0, Nothing, 0)
      don't select ?
      The code is
      Option Explicit
          Dim swMateReference As SldWorks.MateReference
          Dim swFeature As SldWorks.feature
          Dim mateRefEntity As SldWorks.entity
          Dim swModelDocExt As SldWorks.ModelDocExtension
          Dim strMateReferencename As String
          Dim nCount As Long
          Dim refEntType As Long
          Dim mateRefAlignment As Long
          Dim boolstatus As Boolean
          Set swModel = swApp.ActiveDoc
          Set swModelDocExt = swModel.Extension
          swModel.ClearSelection2 True
          boolstatus = swModelDocExt.SelectByID2("Concentric_MateReference-<1>", "POSGROUP", 0, 0, 0, False, 0, Nothing, swSelectOptionDefault)
          Set swFeature = swSelMgr.GetSelectedObject5(1)
          Set swMateReference = swFeature.GetSpecificFeature2
              ' Get the name of the mate reference
          strMateReferencename = swMateReference.Name
          Debug.Print strMateReferencename
              ' Get the number of reference entities in the mate reference
          nCount = swMateReference.ReferenceEntityCount
          Debug.Print nCount
              ' Get the mate reference type for the mate
              ' enity in the selected mate reference
          refEntType = swMateReference.ReferenceType(0)
          Debug.Print refEntType
              ' Get the mate reference alignment for the
              ' mate reference entity in the selected mate reference
          mateRefAlignment = swMateReference.ReferenceAlignment(0)
          Debug.Print mateRefAlignment
              ' Get the  mate reference entity in the mate reference
          Set mateRefEntity = swMateReference.ReferenceEntity(0)
              ' Select the entity
          mateRefEntity.Select4 False, Nothing
        • Re: what POSGROUP in mate?
          Artem Taturevych
          The POSGROUP is mate reference (refer the picture). To select the mate MATE typename should be used.
          Like this:
          swModelExt.Extension.SelectByID2("Concentric1", "MATE", 0, 0, 0, False, 0, Nothing, 0)
          __________________________
          Regards,
          Artem Taturevych
          Application Engineer at Intercad
          http://intercad.com.au/
          Tel: +61 2 9454 4444
              Peter Farnham
              Hi Artem,
              I can see there are no mate references in he's assembly.
              As a side issue, why does the Api help not mention this?
              I did try looking for help regarding POPGROUP and it seems a bit flakey with no real references to it's meaning or use.
                  Artem Taturevych
                  Hi Peter,
                  Yes, this is an issue. Yong is trying to select mates but using incorrect type and example. The example named:
                  so it says that this is for mate references but not mates. These are different types of features in SolidWorks.
                  I agree that the 'POSGROUP' is not very clear name for mate references. I usually use the macro recorder to identify the selection type name. So, for example create an assembly with mate and mate reference and record the macro for selecting of these features and you will see the selection names in the recordered lines.
                  Regards,
                  Artem Taturevych
                  Yong Ning
                  Often use this code
                  use → Mate
                  don't use → POPGROUP
