Hey all,
I'm having trouble with a sheet metal part's Bend-Lines sketch. I recieved this part from a coworker and had to make a change to one of the bend locations. I edited the feature no problem but the sketch "Bend-Lines1" located in the Flat-Pattern feature won't update to the new bend location. Has anyone else experienced this problem?
Thanks.
Hi Andrew, I've run into this before. I don't know if it's the best solution but I ended up deleting the flat pattern from the drawing, closing the drawing, deleting the flat pattern config, open the drawing and re-inserting the flat pattern. Not ideal, especially if there are a lot of dims/annotations involved.
