2 Replies Latest reply on Jan 20, 2013 5:15 PM by Artem Taturevych
    How to understand the function of  GetRootComponent?
    Yong Ning
      How to understand the difference between GetRootcomponent and GetFirstSubFeature?
      GetRootComponent→ http://help.solidworks.com/2012/English/api/sldworksapi/Traverse_Assembly_at_Component_and_Feature_Level_Example_VB.htm
      Traversing Assembly at Component and Feature Levels?
      File = D:\Backup\我的文档\Draw\Assem1.SLDASM
          注解 [DetailCabinet]
          Comments [CommentsFolder]
          设计活页夹 [DocsFolder]
          光源与相机 [EnvFolder]
            环境光源 [AmbientLight]
            线光源1 [DirectionLight]
          前视 [RefPlane]
          上视 [RefPlane]
          右视 [RefPlane]
          原点 [OriginProfileFeature]
          Part1-1 [Reference]
          Part2-1 [Reference]
          配合 [MateGroup]
            距离1 [MateDistanceDim]
        +Part2-1 <默认>
          注解 [DetailCabinet]
          备注 [CommentsFolder]
          设计活页夹 [DocsFolder]
          曲面实体 [SurfaceBodyFolder]
          实体 [SolidBodyFolder]
          材质 <未指定> [MaterialFolder]
          光源与相机 [EnvFolder]
            环境光源 [AmbientLight]
            线光源 1 [DirectionLight]
            线光源 2 [DirectionLight]
          前视基准面 [RefPlane]
          上视基准面 [RefPlane]
          右视基准面 [RefPlane]
          Sketch1 [ProfileFeature]
          Extrude1 [Extrusion]
        +Part1-1 <Default>
          注解 [DetailCabinet]
            细节1 [DetailFolder]
          设计活页夹 [DocsFolder]
          Material <not specified> [MaterialFolder]
          光源与相机 [EnvFolder]
            环境光源 [AmbientLight]
          方程序 [EqnFolder]
          Surface Bodies [SurfaceBodyFolder]
          Solid Bodies [SolidBodyFolder]
          前视 [RefPlane]
          上视 [RefPlane]
          右视 [RefPlane]
          Sketch2 [ProfileFeature]
          包覆1 [Emboss]
        • Re: How to understand the function of  GetRootComponent?
          Yong Ning
          http://help.solidworks.com/2012/English/api/sldworksapi/traverse_subfeatures_example_vb.htm
          If use the GetFirstSubFeature function
          Result
          Sub ls1()
            Dim swApp As SldWorks.SldWorks, swPart As SldWorks.ModelDoc2
            Dim swFeat As SldWorks.Feature
            Set swPart = swApp.ActiveDoc
            With swPart
              ' Get the first feature in part
              Set Feature = .FirstFeature
            End With
            ' While we have a valid feature
            While Not Feature Is Nothing
              ' Get the name of the feature
              FeatureName = Feature.Name
              Message = "Feature: " & FeatureName & Chr(10) & " SubFeatures:"
              Set SubFeat = Feature.GetFirstSubFeature
              ' While we have a valid sub-feature
              While Not SubFeat Is Nothing
                ' Get the name of the sub-feature
                SubFeatureName = SubFeat.Name
                Message = Message & Chr(10) & " " & SubFeatureName
                'message = message & Chr(10) & " " & subFeatureName
                Set SubFeat = SubFeat.GetNextSubFeature
                ' Continue until the last sub-feature is done
              Wend
              ' Display the sub-features
              'swApp.SendMsgToUser message
              Debug.Print Message
              ' Get the next feature
              Set Feature = Feature.GetNextFeature()
              ' Continue until the last feature is done
            Wend
          Feature: 注解
          SubFeatures:
          Feature: Comments
          SubFeatures:
          Feature: 设计活页夹
          SubFeatures:
          Feature: 光源与相机
          SubFeatures:
          环境光源
          线光源1
          Feature: 前视
          SubFeatures:
          Feature: 上视
          SubFeatures:
          Feature: 右视
          SubFeatures:
          Feature: 原点
          SubFeatures:
          Feature: Part1-1
          SubFeatures:
          Feature: Part2-1
          SubFeatures:
          Feature: 配合
          SubFeatures:
          距离1
