Hi all,
I've done some digging around in the forums, but can't seem to find an answer to what I'm trying to do and having some difficulty with.
What I'm trying to do: I'm designing part of a machine which consists of a feedscrew; each revolution of the screw advances one part along a conveyor. The part is basically an extruded oval.
Making a Helix and then sweeping the profile of the part along the helix doesn't work, because the material left over on the screw interferes with the part a few degrees before and after the point of engagement.
I understand the use of Solid Sweep (vs. Profile Sweep), and Solid Sweep should give me the effect I'm looking to create. However, Solid Sweep seems to only work with a cylindrical solid, not any other shape. As my part is an extruded oval, I can't quite think of a workaround for this.
Any suggestions? Attached is a part file showing the dilema - I want to make a Solid Sweep (Cut) using the body "Part Representation" and "Helix/Spiral1" features, but it won't allow me to make the feature.
Thanks in advance!
-Iain
(SolidWorks 2012, SP5.0)
Hi Iain,
the solid profile is not valid for a solid sweep cut. See attached. I'm not sure what version you are on so you might not be able to read it (I did the attached in SW2012) so I provided to screen images. Frankly, Think of Solid Sweep's primary use as a tool for cutting using a rotary tool. - thus, I do not see how you would use the profile you created as a tool for cutting in real life?
Regards
Mark
