Add-in error when calling 'OnCmd' method
Question asked by Klaas Oudejans on Jan 15, 2013
Latest reply on Jan 21, 2013 by Klaas Oudejans
Dear readers,
I have build an add-in for our Enterprise PDM setup. We use it with Inventor. On releasing files, I want this add-in to export pdf files for all drawings in the release batch.
I got this add-in to work, but it only seems to work once. The next time I run it, I get an error stating that:
"Call to method 'OnCmd' in add-in 'ExportPFFiles', written by company 'Intralox' failed. Error cod = 0x080131603 (Unknown error 0x80131603).
But at some point, this error message will not show, and I will be able to run it once again. I don't know where or when this reset happens.
I also sometimes get an error message about the RPC server being unavailable.
I have no idea where this is going wrong, and I am hoping that somebody can point me in a direction of what can be causing these errors.
I am using Visual C#.
This is how I started my code:
using System;
using System.IO;
//using System.Windows.Forms;
using System.Collections.Generic;
using System.Text;
using EdmLib;
using Inventor;
namespace ExportPDFFiles
    public class Addin : IEdmAddIn5
        public Inventor.Application oApp;
        public Inventor.AssemblyDocument oAssyDoc;
        public void GetAddInInfo(ref EdmAddInInfo poInfo, IEdmVault5 vault, IEdmCmdMgr5 cmdMgr)
            poInfo.mbsAddInName = "ExportPDFFiles";
            poInfo.mbsCompany = "Intralox";
            poInfo.mbsDescription = "Exports all .pdf files that are related to the assembly on which this add-in is executed";
            poInfo.mlAddInVersion = 1;
            poInfo.mlRequiredVersionMajor = 5;
            poInfo.mlRequiredVersionMinor = 2;
            //This add-in is reached through a hook. Everytime a file passed to a new state, this add-in is called.
            cmdMgr.AddHook(EdmCmdType.EdmCmd_PostState);
        public void OnCmd(ref EdmCmd edmCmd, ref Array data)
            try
                if (data == null)
                    return;
                //Get the current vault
                IEdmVault11 vault = (IEdmVault11)edmCmd.mpoVault;
                Boolean bFilesPDFHandled = false;
                // this doesn't do much. Everytime the sequence is here, it is called by the poststate trigger / hook
                if (edmCmd.meCmdType == EdmCmdType.EdmCmd_PostState)
               And so forth
