3 Replies Latest reply on Jan 14, 2013 5:44 AM by Artem Taturevych
    Change Custom Property template via API
    Mika Malo
      I have built few different custom property templates with Property Tab -builder. Each suites for different purpose parts and assemblies.
      I am looking a way to apply and change proper template via macro but can't find any info of the matter.
      Anyone?
      Thanks.
      -Mika
        • Re: Change Custom Property template via API
          Artem Taturevych
          The template is nothing but XML files. Something like the following:
          <?xml version="1.0" encoding="UTF-8"?>
          <CPTemplate>
            <CPSheet>
              <GroupBox Label="Groupbox" PropName="Groupbox2" DefaultState="Expanded">
                <Control Label="Textbox" PropName="CheckedBy" ApplyTo="Config" Type="TextBox" DefaultValue="Admin" Mode="Text" />
              </GroupBox>
            </CPSheet>
          </CPTemplate>
          So you can easily create your templates. Then just place it into a template location: File Locations->Custom Property Files. In order to refresh the task pane just switch the pages via the SldWorks::ActivateTaskPane.
          So the combination of SolidWorks API and XML readers/writers will do the job.
          __________________________
          Regards,
          Artem Taturevych
          Application Engineer at Intercad
          http://intercad.com.au/
          Tel: +61 2 9454 4444
