34 Replies Latest reply on Jul 29, 2013 3:55 PM by Brian Marchand
    Copy Function in 2013 not working as in 2012
    Brian Marchand
      Using 2013 sp1
      In 2103 if I selected a component or an assembly, use the edit-copy, then click on the screen to clear the highlight, then do a edit-paste, Solidworks would create an exact copy directly on top of the part I copied. This was very handy.
      No when I do the same thing, it puts the copy wherever the curser is sitting
      Is there a way to get this back or maybe it wasn't supposed to work that way, but it was nice
      If not does anyone know a way, without mateing, to put an exact copy on top of another??
      Its handy because say you have a main assembly with a conveyor in it. You pattern your item thats on the conveyor. Now you create 5 stations that do work on that conveyor.
      Intead of copying and mateing the item inside your sup assembly, I used to be able to copy, paste, then drag to new sub assembly and it was there, just have to fix it so it didn't move. I would do a bunch of work, then delete it.
      I guess it was just quick and I was used to doing it
      Thanks for any input
