5 Replies Latest reply on Jan 10, 2013 11:24 AM by John Seyler
    Visual Basic Problem
    Greg Johnson
      I have a combo box control inside a data grid view so I have to have code to be able to enter a custom value. But my code doesn't work, the code works fine if the user types in a custom value but doesn't work if it is one of the values from the combo box list. Here is a copy of my code that performs the task. In both cases the variable strValue contains the value that we are looking for but when the program exits from the sub the value is removed if it was selected from the list. Does anyone have any ideas on how to fix this?
          Private Sub dgdRevisions_CellValidating(ByVal sender As Object, ByVal e As System.Windows.Forms.DataGridViewCellValidatingEventArgs) Handles dgdRevisions.CellValidating
              'These lines allow the user to type their own values into the datagridview comboboxes
              If e.ColumnIndex = colDescriptionLine1.DisplayIndex Then
                  Dim combobox As DataGridViewComboBoxCell = dgdRevisions(e.ColumnIndex, e.RowIndex)
                  'Store e.FormattedValue in Variable
                  Dim strValue As String = e.FormattedValue.ToString.ToUpper
                  'Clear text
                  dgdRevisions(e.ColumnIndex, e.RowIndex).Value = ""
                  'Clear existing Items in combobox
                  'Add default Items to combobox
                  PopulateStandardDescriptions(e.ColumnIndex, e.RowIndex)
                  'Add user value to combobox
                  If Not combobox.Items.Contains(strValue) Then
                      If Not strValue = "" Then
                  dgdRevisions(e.ColumnIndex, e.RowIndex).Value = strValue
