VMVlad Munteanu10/01/2013
I am trying to use the macro that is provided in the VBA help library with slight modifications .
http://help.solidworks.com/2012/English/api/sldworksapi/Pack_and_Go_an_Assembly_Example_vb.htm
What I am trying to do is while an assembly is open, get all the references contained in that assembly and then based on some pre-defined criteria, remove from that list some references which I don’t want to save. So when the pack and go operation is completed the removed references will not be copied over.
I was successful in getting the pgSetFileNames to have empty entries for the removed references and finish the pack and go. It seems to work some times and other times it completely ignores that list (pgSetFileNames) and copies everything. So when it doesn’t work the list pgSetFileNames still contains empty references but it seems to get the full list of references from somewhere else. I don’t know if the failures I am getting are due to assemblies having routing assemblies or not. There seems to be a correlation between having routing assemblies and the macro ignoring the truncated list of references pgSetFileNames.
What I need it to do is:
pgSetFileNames – list of documents I want the Pack And Go operation to use
I want the following line to use the values in the pgSetFileNames array. Statuses should be a function of pgSetFileNames
statuses = swModelDocExt.SavePackAndGo(swPackAndGo)
Thank you all for your help!
Here is part of my code, which is almost identical to the SolidWorks Macro listed on their website if it will help troubleshoot:
Public Sub pack_and_go()
Dim swModelDoc As SldWorks.ModelDoc2
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swPackAndGo As SldWorks.PackAndGo
'Route Stuff
Dim swTopLevelAssembly As SldWorks.AssemblyDoc
Dim rtRouteManager As SWRoutingLib.RouteManager
Set swModelDoc = swApp.ActiveDoc
If swModelDoc Is Nothing Then
    swApp.sendmsgtuser ("Please open a document")
Else
Set swModelDocExt = swModelDoc.Extension ' Get Pack and Go object
Dim routemgr As Object
Set routemgr = swModelDoc.GetRouteManager()
If swModelDoc.GetType = swDocASSEMBLY Then
Set swTopLevelAssembly = swModelDoc
Set rtRouteManager = swTopLevelAssembly.GetRouteManager
If rtRouteManager Is Nothing Then
  1. Debug.Print "No RouteManager found in top-level document: " & swTopLevelAssembly.GetPathName
Exit Sub
Else
Set swPackAndGo = swModelDoc.Extension.GetPackAndGo
' Include any drawings and simulation results
  1. swPackAndGo.IncludeDrawings = True
' Get number of documents in assembly
namesCount = swPackAndGo.GetDocumentNamesCount
status = swPackAndGo.GetDocumentNames(pgFileNames) 'added set
'Get current paths and filenames of the assembly's documents
  1. Debug.Print "  Current path and filenames: "
If (Not (IsEmpty(pgFileNames))) Then
    For i = 0 To UBound(pgFileNames)
        Debug.Print "    The path and filename is: " & pgFileNames(i)
    Next i
'' Get current save-to paths and filenames of the assembly's documents
'status = swPackAndGo.GetDocumentSaveToNames(pgFileNames, pgFileStatus)
  1. Debug.Print ""
  2. Debug.Print "  Current default save-to filenames: "
    Next i
status = swPackAndGo.GetDocumentSaveToNames(pgFileNames, Nothing)
'Create your own filenames for the model's documents
ReDim pgSetFileNames(namesCount - 1)
'Debug.Print ""
'Debug.Print "  My Pack and Go path and filenames before adding prefix and suffix: "
j = 0
For i = 0 To (namesCount - 1)
         myFileName = pgFileNames(i)
         ' Determine type of SolidWorks file based on file extension
             If InStr(LCase(myFileName), "sldprt") > 0 Then
                 'myFileName = j & ".sldprt"
                 fullpath = myFileName
                 fileName_function (fullpath)
                 'myFileName = myPath & fname
                 Call ExcelSearch
             ElseIf InStr(LCase(myFileName), "sldasm") > 0 Then
                 'myFileName = j & ".sldasm"
                 Call ExcelSearch
            ElseIf InStr(LCase(myFileName), "slddrw") > 0 Then
                 'myFileName = j & ".slddrw"
                 Call ExcelSearch
             Else
                 ' Only packing up SolidWorks files
                 Exit Sub
        pgSetFileNames(i) = mypath & fname2 'fname 'myPath & fname 'myFileName
         j = j + 1
Next i
reDim pgSetFileNames(namesCount - 1)
status = swPackAndGo.SetDocumentSaveToNames(pgSetFileNames)
'swPackAndGo.AddPrefix = "SW"
'swPackAndGo.AddSuffix = "PackAndGo"
' Verify document paths and filenames after adding prefix and suffix
ReDim pgGetFileNames(namesCount - 1)
ReDim pgDocumentStatus(namesCount - 1)
pgGetFileNames = pgSetFileNames
status = swPackAndGo.SetSaveToName(True, mypath)
status = swPackAndGo.GetDocumentSaveToNames(pgSetFileNames, pgDocumentStatus)
‘Debug.Print ""
'Debug.Print "  My Pack and Go path and filenames after adding prefix and suffix: "
  1. Debug.Print "    My path and filename is: " & pgGetFileNames(i)
Next i
‘Pack and Go
