I have tried everything I can think of to build a part like this that I can unfold in sheet metal to get the flat layout. If I do it with a seam parallel to the axis it is easy. But that's not what we need in real life.
Any suggestions? This seems like a pretty common real life sheet metal situation, the program should be able to handle it.
Rick
If you start in sheet metal, make a base flange that is really short (.0001) and then Hem it, then use a second Hem to complete the circle, Do a cut extrude to put in your surface cut in the side and flatten. Might not be perfect, but gets you the result.
Hopefully you can see the image well enough.
