Hello Lads,
Didn't really know where to post this, I'm new around here! So I have a problem, whenever I try to Sweep Boss/Base, it allows me to select Profile and Path, but when I try to press the green tick, a white box appears near the question mark. Tryed many times, the problem still persists. Re-install didn't work either. Strangely, I have another problem: at the startup an error occurs, saying:
An error has occurred in the script on this page.
Line: 84
Char: 2
Error: The value of property 'getVertica' is null or undefined, not a Function object
Code: 0
URL: file:///D:/Program%20Files/SolidWorks%20Corp/SolidWorks/data/taskpane/common/taskPaneFuncs.js
Then another similar error appears. What should I do?
Try a clean install per this document.
