using 2013 sp1.. importing igs files crash SW... still trying but have switched options off and on..
SW pops a dialog saying the default templates are not valid.... continue with blank? yes..
SW has encountered a problem and needs to close...
I've tried other igs files I have, that SW 2012 had no problems importing.. any one have an idea?
I've run SW Rx and sent the files in... will keep trying..
jb...
follow up..
set the igs import options to ..
Free point/curve entities / import as 3D curves..
Perform full entity check...
File spec unit
Show IGEs levels
still gives warning about bad template, but imports as parts.
of course I have to hit OK for each parts as it runs.. not really acceptable for real life..
2013 is so far turning out to be the worst for bugs on my end sense I started in 2004..
