Is there any way to remove an ALT FILENAME from a Toolbox part?
We had a user start using “Customize Hardware” in the toolbox…they entered a value under the ALT FILENAME field.
So now there are two parts : one named the default way “PHMS xxxx…” and another using the alt filename “MS51957….”
Now, when inserting this screw, although it says it’s going to use the default part, it uses the newly created part instead…however, there is no way to customize this new part, it doesn’t show up in the “Customize Hardware” box.
i ended up editing the swbrowser.mdb using MS Access to remove those fields from the parts.
