CSCoen Sleiderink08/01/2013
I'm a student who is trying to write some code using macro's for an assignment. But i'm stuck with this run-time error 91. I've tryed a lot of things but none seem te solve the problem.
Below you can see a part of te code i wrote. And where i get the error. The bold line of code is where the error occurs. It is highlighted yellow on my screen.
Option Explicit
Dim part As Object
Dim swFeatMgr As SldWorks.FeatureManager
Private Sub cmdBuild_Click()
    Set swModel = swApp.NewPart
    swModel.SetAddToDB True
    swModel.SetUserPreferenceIntegerValue swUnitsLinear, swMM
    'MATERIAAL
    If chkSteel.Value = True Then
        swModel.SetUserPreferenceDoubleValue SwConst.swMaterialPropertyDensity, 7800
        swModel.SetUserPreferenceStringValue SwConst.swMaterialPropertyCrosshatchPattern, "ISO (Steel)"
    'PROFIEL
If optExtrude.Value = True Then
    txtAngle.Enabled = False
    txtRadius.Enabled = False
    Dim varHeight As Double
    Dim varWidth As Double
    varHeight = CDbl(txtHeight.Text) / 1000
    varWidth = CDbl(txtWidth.Text) / 1000
    Set part = swApp.ActiveDoc
    part.SketchManager.InsertSketch True
    Dim skSegment As Object
    Set skSegment = part.SketchManager.CreateLine(0#, 0.045159, 0#, 0#, 0#, 0#)
    Set skSegment = part.SketchManager.CreateLine(0#, 0#, 0#, 0.044261, 0#, 0#)
    part.SetPickMode
    Dim myDisplayDim As Object
    Set myDisplayDim = part.AddDimension2(-0.02183164339539, 2.33269614361702E-02, 0)
    Dim myDimension As Object
    Set myDimension = part.Parameter("D1@Sketch1")
    myDimension.SystemValue = varHeight / 1000
    Set myDisplayDim = part.AddDimension2(2.21307070035461E-02, -1.76447528812057E-02, 0)
    Set myDimension = part.Parameter("D2@Sketch1")
    myDimension.SystemValue = varWidth / 1000
    part.SetPickMode
Can anyone help me with this problem?
