pdmworks api:bump assembly revision causes references vanished
Discussion created by Guest on Sep 1, 2006
My MIS director has made a web interface using php. Up until now we almost never release assemblies, only release parts. Now, the assemblies are released with the parts and we have to do a bump revision of the assembly after the release. This is done thru the web interface to the api using the pdmworks api call for bumping revision.
the problem is that after the revision is bumped using the api, pdmworks doesn't show the assembly's references. It also doesn't ope/checkout the assembly with references.
Is there a snippet or a fix for this?
