4 Replies Latest reply on Oct 11, 2013 1:07 AM by John Highet
    Save As
    Zach Zimmerman
      Ever since I upgraded to SW2013 and do a save as, 75% of the time the save as copy box is checked. Is there a setting that does this automatically? I've noticed this same phenomena in my drawings with the auto-start projected view in the view palette of my task pane. Please help.
        • Re: Save As
          John Seyler
          I believe both boxes will remember what was checked the last time you completed that action. I do not have SW in front of me this second but try changing it and see what happens when you run it a second time.
          • Re: Save As
            jason van clark
            Tools>Options>Messages/Errors/Warnings
            uncheck the box next to "____ is being referenced by other open documents.  "Save As" will replac..."
            Open an assembly
            Open on of the components in the assembly
            File>Save As
            The message box will appear.  Check the 'Don't show again' box in the lower left and select the 'Save as new name' optionCapture.PNG
            This will reset SWX for you
            Jason
              • Re: Save As
                John Highet
                Jason, thanks for this tip.  We finally upgraded to SW2013 a couple weeks ago and I had been screwing things up all over because I was used to the "save as copy" check box being unchecked.  Huge sigh of relief after following your instructions and having the default back to unchecked.  It's the little things...
                Thanks again,
                John
