I have an interesting situation and I’m wondering if anyone else has ever seen this. About a month ago I renamed a folder in EPDM that contains engineering drawings for a project. Prior to this one of the engineering leads had created a shortcut to the original folder and placed it on his desktop. Today we discovered that the shortcut, using the old folder name still takes him to the folder and displays it as the old folder name. Upon further investigation we saw that it looks like an exact representation of the renamed folder. However, if you take the path out of the shortcut and copy it into EPDM you receive an error that the folder doesn’t exist. I have tried to create a shortcut to replicate the problem but receive the same error. It appears that only the shortcut created before the folder rename will do this. Hope this makes sense.
Hi Melissa,
I have seen this behavior before.
My conclusion was the folder is a locally cached copy of the folder the user had permissions to view using Windows but when entering through the EPDM interface causes EPDM to try to manage the viewing which throws the error.
Here is the reader's digest version of my current understanding on how the navigation works. Others may know significantly more about this so they can add to this if needed:
Sort of like working offline...but not completely.
Hope this helps.
Tim
