10 Replies Latest reply on Jan 10, 2013 11:54 PM by Artem Taturevych
    LoadSplineData() Does not work!!!
    Unspecified Unspecified
      I've been trying to get the LoadSplineData() to work and have had no sucess at all.  I've wasted 8+hrs trying to figure this out...
      all I want to freaking do is just update the Motor data via a text file with the same name!!!!  I don't understand why this is so difficult!!! The online tutorial and documentation is uesless!
      Everything works except for the "LoadSplineData("C:\....csv")  command
      I keep getting a run-time error '-2147417851 (80010105)':
      Automation error
      The server threw an exception.
      Below is an excerpt from my code:
      vMotionFeatures = swMotionStudy3.GetMotionFeatures
          Dim strMotor As String
          For i = 0 To UBound(vMotionFeatures)
             Set swFeat = vMotionFeatures(i)
              If swFeat.GetTypeName = "AEMLinearMotor" Then
                  For n = 0 To 3
                      strMotor = "LinearMotor5" & n
                      If swFeat.Name = strMotor Then
                          'do thing here
                          Set swMotorFeat = vMotionFeatures(i).GetDefinition
                         retval = swMotorFeat.LoadSplineData("C:\Motor5" & i & ".csv")
                  Next n
                  n = 0
           Next i
      Please!!! Any help would be much appreciated!
