2 Replies Latest reply on Jan 6, 2013 5:50 PM by Artem Taturevych
    Delete line dimension
    Joecel Torres
      Hi All,
      How can i delete a dimension of a line w/o selecting it first?
      Is there a function like ModelDoc2:: SketchConstraintsDel where in you just need to select the line to delete the constraint?
      Thanks!
        • Re: Delete line dimension
          K. C
          Select the sketch and delete
          Set Part = swApp.ActiveDoc
          boolstatus = Part.Extension.SelectByID2("D1@Sketch1@Part1.SLDPRT", "DIMENSION", 2.59476034393162E-02, 0.034195848241218, 0, False, 0, Nothing, 0)
          Part.EditDelete
          Regards
          K.C
            Artem Taturevych
            I haven't found a method to get the dimension from segment. You should work in opposite direction: traverse all dimensions in the sketch: Feature::GetFirstDisplayDimension->Feature::GetNextDisplayDimension and get the attached entities from every dimension to find the dimension which is attached to you line: IDisplayDimension::GetAnnotation->Annotation::GetAttachedEntities3. Then select and delete this dimension.
            __________________________
            Regards,
            Artem Taturevych
            Application Engineer at Intercad
            http://intercad.com.au/
            Tel: +61 2 9454 4444
