7 Replies Latest reply on Jan 6, 2013 9:48 PM by Dan Miel
    How to open a macro form to the front?
    Tom Strohscher
      I've created a macro with a form.  When I run the marco the corm open behind SW and the user can't see it.
      How can I open the form to the front?
        • Re: How to open a macro form to the front?
          Steven Smith
          Add the X64 module as a second module.
          Then copy and paste the Userform module1 text into your initial module.
          This will bring your userform to the front.
            Artem Taturevych
            This is the known issue of x64 VBA macros. There is a workaround to forcibly make the SolidWorks window parent to the macro. Please refer the solution S-013887 in Knowledge Base. You may find the sample macro there.
            You can also find a sample on Keith's web-site: http://www.cadsharp.com/macros/keep-vba-user-form-on-top-on-64-bit-systems-vba/
            __________________________
            Regards,
            Happy New Year!
            Artem Taturevych
            Application Engineer at Intercad
            http://intercad.com.au/
            Tel: +61 2 9454 4444
              Keith Rice
              Thanks Artem.
              Tom--- the macro on my site that Artem pointed to is a vastly simplified version of the macro provided in solution S-013887, so you may find it easier to work with. Also, it centers the user form in the middle the screen by first determining the height and width. Should you want to modify the placement, you will need to modify these lines:
              lFormXval = sWinPlacementForm.rcNormalPosition.Right / 2
              lFormYval = sWinPlacementForm.rcNormalPosition.Bottom / 2
              'X and Y locations for form
              lXval = lSolidWorksXval - lFormXval
              lYval = lSolidWorksYval - lFormYval
              Keith
              Video Tutorials for the SolidWorks API
                Josh Brady
                Or update to 2013.  I believe (according to what I've read) that the problem of forms popping up behind SW is due to VBA being 32 bit while SW is 64, so VBA has to run in a separate process that can't take focus.
                Per the What's New, 2013 has a 64 bit version of VBA, so this problem should be solved.  Caveat: I haven't tried this myself yet...
                  Tom Strohscher
                  Thanks I got it all working.
                  I understand we have gotten back on maint and will be upgrading from 2011 to 2013.
                  Will I have to convert my macros to 64 bit?
                      Dan Miel
                      Tom,
                      If you have an api call that has a Long number you will need to convert your Longs to be 64 bit compatible.  If the only api calls you have are in the module to put the form on top then you can remove the module and you should be fine.
                      Dan Miel
                      SW 2011
                        Dan Miel
                        I thought I would add more information in case a person uses api calls other that putting a form on top.
                        In one of my programs I use an api call to get the name of the computer that is running the program. Below is the code I used. It is written so that the program can be used in VBA or VBA7.
                        You can Google PtrSafe or Longptr for more complete information.
                        I hope this helps.
                        ‘Written Dan Miel 10-16-2012
                        ‘****If VBA7 use the first call or if VBA use the second.
                        #If VBA7 Then  '11-16-2012
                        Declare PtrSafe Function GetUserName Lib "advapi32.dll" Alias "GetUserNameA" (ByVal lpBuffer As String, nSize As LongPtr) As LongPtr
                        #Else
                        Declare Function GetUserName Lib "advapi32.dll" Alias "GetUserNameA" (ByVal lpBuffer As String, nSize As Long) As Long
                        #End If
                        ‘***Use this function to return the computer name.
                        Function UserName() As String
                             ' Dimension variables
                            Dim ret As LongPtr ', UserName As String
                        #Else
                            Dim ret As Long ', UserName As String
                        #End If
                             Dim lpBuff As String * 25
                             ' Get the user name minus any trailing spaces found in the name.
                             ret = GetUserName(lpBuff, 25)
                             UserName = Left(lpBuff, InStr(lpBuff, Chr(0)) - 1)
                             ' Display the User Name
                             'MsgBox UserName
                             End Function
