I have a sketch with a point (Point43) which is coincident with another point (Point145) which is defined in the same model, but not the same sketch. How can I find Point145?
Dear Ted
As I understood what you have written, I can tell you a simple thing. Check whether you have activated view sketches button. See the figure below.
There you can see there are 2 different sketches; one is having a line and a point and the other is having just a point.
Hope this will help.
Monika
I can see the sketches, I can't select the sketch which contains Point145 so I can see what defines its location.
Ted,
What if you houver over the sketch and RMC and select other?
if not you can always hide the solid body then select the sketch.
Frank
At the top of your feature manager(next to the blue filter funnel) there is a search box, type in what you are looking for
and it will find it and turn off everything else.
That was the first thing I tried, but no luck
Dear Ted
Monika
