Folks,
I have been trying to do the simple task of putting a #10-24 threaded hole in a boss on a sheet metal part. I use Hole Wizard, define the threaded hole and locate it accordingly. However, when I click Check SW crashes. It doesn't do that on a "normal" model. Any ideas?
Assuming that it's a boss that allows for the insertion of the proper sized hole it should work. What I have noticed is, if you have the same size hole in the boss as the tap drill size it won't work. Just make the initial hole a few thousanths less to make sure you 'cut' something when using the Hole Wizard.
