5 Replies Latest reply on Dec 20, 2012 1:27 PM by Aaron Larson
    Initiate the "Insert Component" property manager
    Aaron Larson
      Is there a way to initiate the "Insert Component" property mangager without completing the component insertion?  Below is my reason:
      We have a design library which has many folders and subfolders essentially with a goal of having 1 part per folder so that the users can logically navigate to find what they need.  This is really cumbersome and because the parts are checked into our PLM system.  So, updating a series of parts from the sytem is cumbersome because each part has to be checked out into its own folder to avoid issues.
      I have a database apart from the PLM that contains some basic information about the parts in the library.  I have a nice little user form in a macro that searches through this database to locate a part.  What I'd like to be able to do is insert a part from the form. The AddComponent functions don't get what I need because I want the smart mate functionality of the library components.  So I'd like to be able to pull the part in the "Insert Component" property manager and fire that so the user can "drag & drop" the components into their assembly.
      BTW we're on 2009 and soon to upgrade to 2011.
        • Re: Initiate the "Insert Component" property manager
          Keith Rice
          Aaron,
          You can activate nearly any command in SolidWorks using ISldWorks::RunCommand. I recommend you check out this blog post for details on how to use this API call.
          This code worked for me in 2013 and I am guessing it will work in 2009:
              Set swModel = swApp.ActiveDoc
              swApp.RunCommand swCommands_InsertComponents, Empty
          Keith
          Video Tutorials for the SolidWorks API
              Aaron Larson
              Thank you so much - great blog post.  I too have been writing macros for far too long to have not known about that call.  This isn't as elegant as replicating the drag and drop from the design library but it gets the job done efficiently.
                Aaron Larson
                Here's one more tag along for this.  I'm using the DocumentInvisible property to load the library file into memory so it is available for the "Insert Component" command.
                The only problem is... when I load it "invisibly" it doesn't seem to appear in the list of components.
                Private Sub cmdInsertPart_Click()
                Dim InsertComp As ModelDoc2
                Dim FileName As String
                Dim fileerror As Long
                Dim filewarning As Long
                'See if any document is open
                If swModel Is Nothing Then
                    RetVal = MsgBox("No document open.  Please open an assembly and try again.", vbOKOnly + vbMsgBoxSetForeground)
                    Exit Sub
                'Make sure an assembly is open
                If Not swModel.GetType = swDocASSEMBLY Then
                    MsgBox ("Active window is not an assembly.")
                    Exit Sub
                'Make sure a result is selected
                If Me.lstResults.ListIndex = -1 Then
                    MsgBox ("Nothing selected.  Make a selection from the list and try again.")
                    Exit Sub
                swAssy = swModel.GetTitle
                FileName = FileLocation & ItemArray(Me.lstResults.ListIndex, 0) & ".SLDPRT"
                'Set Document visibility to Invisible so part is accessible from Insert Component PropMgr
                'swApp.DocumentVisible False, swDocumentTypes_e.swDocPART
                'Open the selected part
                Set InsertComp = swApp.OpenDoc6(FileName, swDocPART, swOpenDocOptions_Silent, "", fileerror, filewarning)
                'Active the target assembly
                swApp.ActivateDoc (swAssy)
                'Initiate the "Insert Component" command
                bret = swApp.RunCommand(swCommands_InsertComponents, Empty)
                'Close the selected library document
                swApp.CloseDoc (FileName)
                'Reset document visibility
                'swApp.DocumentVisible True, swDocumentTypes_e.swDocPART
                Message was edited by: Aaron Larson I should mention that the reason I'm interested in loading the library component only to memory and not the screen is that we deal with very large and unruly assemblies and I don't want the user to have to deal with waiting for Solidworks to toggle screens just to insert the component.
