You can save the bom as a block and link that block to the dwg drawing file so that if you make changes to the block it will auto update the dwg drawing file. You can also insert an object into your dwg drawing which can be an excel file. If you do this and check the link box it will link to the excel file so if you make changes to the excel file it will also udate the dwg drawing.
