I am having problems with Flat Patterns, I use lofted bends but I am not sure if this is best, I draw a lot of pipe spools that we have cut on a tube mill laser all of the flat patterns I create from parts are always wrong, I have to fudge the pipe diameter to get them close to the target circumference.
I am looking for a contestant way of creating flat patterns that are the correct circumference of the pipe I have drawn,
I have tried sketch on the OD ID and on the mean line, I do have to leave .5 mm out of the circumference to use the lofted bend but this should be nominal when it comes to the correct size flat pattern.
What bend allowance are you using?
