Having trouble with this flexible assembly, maybe you guys can find the problem.
Was working fine, then I shortened the linear actuator by about an inch. I had to lock the toggle clamp to adjust the placement of the yoke. Now after unlocking the toggle it still won't move.
Changed to Pack and Go zip
Hi Gerald
I fixed your base plate in position and then made your toggle clamp flexible, everything worked ok then for me. See assembly attached
Paul
