MWMary West17/12/2012
I am hoping there is an answer to this.
In my code below, the user is prompted to select a part or assembly to open.
Once opened, it loops through all loaded models and exports each to STEP.
For a PART, I get the result I want, which is just the geometry of that PART saved in a same-named STEP file.
For ASSEMBLY, it always puts all the “child” geometry into the STEP, when I just want references to the PARTs.
Am I missing a preference setting?  Or is this even possible?  Any workaround?
public static void saveSample()
   object[] models;
   swApp.Command((int)swCommand_e.swFileOpen, null);
   models = (object[])swApp.GetDocuments();
   int count = swApp.GetDocumentCount();
   swApp.SetUserPreferenceToggle((int)swUserPreferenceToggle_e.swStepExportSplitPeriodic, false);
   //walk the list of models
   for (int index = 0; index < count; index++)
      bool stepsaved = false;
      modDoc = (ModelDoc2)models[index];
      modDoc.Rebuild(0);
      modDocExt = modDoc.Extension;
      //compose path name based on original file name
      string stNewPath = modDoc.GetPathName();
      stNewPath = stNewPath.Remove(stNewPath.Length - 7);
      if (modDoc.GetType() == (int)swDocumentTypes_e.swDocPART)
         string stPathStep = stNewPath + ".step";
         int errors = 0, warnings = 0;
         stepsaved = modDocExt.SaveAs(stPathStep, (int)swSaveAsVersion_e.swSaveAsCurrentVersion, 0, null, ref errors, ref warnings);
         //This works nicely
      else
         string stPathStep1 = stNewPath + "_1.step";
         string stPathStep2 = stNewPath + "_2.step";
         //Both of these save the entire assembly into one step file
         stepsaved = modDocExt.SaveAs(stPathStep1, (int)swSaveAsVersion_e.swSaveAsCurrentVersion, 0, null, ref errors, ref warnings);
         stepsaved = modDocExt.SaveAs(stPathStep2, (int)swSaveAsVersion_e.swSaveAsCurrentVersion (int)swSaveAsOptions_e.swSaveAsOptions_DetachedDrawing, null, ref errors, ref warnings);
