Hello All,
I apologize if this is somewhere in the forums already but I can't seem to dig up what I'm looking for in the help or forums.
I'm new to configurations, and I'm sure this is actually really simple: All I want to do is make a hole pattern configuration specific. It's not really even a pattern, they're holes that I'm putting in based on a top-down assembly model that are meant to be coincedent with certain parts.
So basically, I need the entire sketch for the Hole Wizard Feature to be specific to the particular Configuartion. I've tried "right-clicking" the feature and saying "This Configuration" in the drop down menu, but for some reason it resets itself to "Linked to Parent Configuration" immediately. Is this the option I should be changing?
Hopefully I've provided enough info for some basic help on how to do this.
Thanks in advance!
Mike
Mike,
You best option (most stable) may be to create distinct instances of hole patterns for each config. When a Hole Pattern isn't used, it can be supressed in the config it isn't used in.
Good luck.
Alan
