EPDM Tasks: How to add macro code to a convert task
Question asked by George Bon on Dec 17, 2012
Latest reply on Dec 18, 2012 by George Bon
Hi all,
I would like to create an EPDM task that inserts a block on SW drawings and then exports them to a DWG format.
We have a macro that inserts the block working on its own, and we have the EPDM convert to DWG task working as well.
The problem is when trying to insert the macro code in the task, things do not work as expected and it looks like there is no way of debugging the task code. I am getting a log error as follows:
Error while converting file 'C:\EPDM\2012048\IPD\Drawings\380\ML380-C-045.SLDDRW':
An unexpected error occurred while executing the generated script. Script syntax error?
Error number: 438
Error description: 'Object doesn't support this property or method'
Here is the modified convert task code (the sub 'Applystamp' is the only modification):
Dim swApp As Object
Dim swDrawing As SldWorks.DrawingDoc
Dim swAssembly As SldWorks.AssemblyDoc
Dim swExtension As SldWorks.ModelDocExtension
Dim swConfMgr As SldWorks.ConfigurationManager
Dim swPDFExport As SldWorks.ExportPdfData
Dim swDocSpecification As SldWorks.DocumentSpecification
Dim errors As Long
Dim warnings As Long
Private Declare Function SHCreateDirectoryEx Lib "shell32" Alias "SHCreateDirectoryExA" (ByVal hwnd As Long, ByVal pszPath As String, ByVal psa As Any) As Long
Private Declare Function PathIsRelative Lib "shlwapi.dll" Alias "PathIsRelativeA" (ByVal pszPath As String) As Long
Function PathAppend(path, more) As String
    If Not Right(path, 1) = "\" Then
        path = path & "\"
    If Left(more, 1) = "\" Then
        more = Mid(more, 2)
    PathAppend = path & more
End Function
Sub Log(message)
    Dim errorLogFolder As String
    Dim errorLogPath As String
    ' Determine error log output path
    errorLogFolder = "[ErrorLogPath]"
    ' Trim \ from the start
    If Left(errorLogFolder, 1) = "\" Then
        errorLogFolder = Mid(errorLogFolder, 2)
    ' Build full root
    If PathIsRelative( errorLogFolder ) = 1 Then
        errorLogPath = PathAppend("<VaultPath>", errorLogFolder)
    Else
        errorLogPath = errorLogFolder
    ' Create directory if not exists
    SHCreateDirectoryEx ByVal 0&, errorLogPath, ByVal 0&
    errorLogPath = PathAppend(errorLogPath, "<TaskInstanceGuid>.log")
    ' Write error to output file
    Open errorLogPath For Append As #1
    Print #1, message
    Close #1
Sub CreatePath(path)
    If SHCreateDirectoryEx(ByVal 0&, path, ByVal 0&) = 0 Then
        ' Create temp file
        Open path & "~$holder" For Append As #1
        Close #1
Sub KillHolder(path)
    On Error Goto Ignore
    Kill path & "~$holder"
Ignore:
Function GetExtension(docType, fileFormat)
    first = InStr(1, fileFormat, "(")
    last = InStr(first, fileFormat, ")")
    extensions = Mid(fileFormat, first + 1, last - first - 1)
    If InStr(1, extensions, ";") > 0 Then
        Dim all As Variant
        all = Split(extensions, ";")
        If UBound(all) >= docType - 1 Then
            ext = all(docType - 1)
        Else
            ext = "*." ' Nothing
    Else
        ext = extensions
    GetExtension = Mid(Trim(ext), 2)
End Function
Sub SetConversionOptions(ext)
    ' PDF options
    If LCase(ext) = ".pdf" Then
        swApp.SetUserPreferenceToggle swPDFExportInColor, [PdfInColor]
        swApp.SetUserPreferenceToggle swPDFExportEmbedFonts, [PdfEmbedFonts]
        swApp.SetUserPreferenceToggle swPDFExportHighQuality, [PdfHighQuality]
        swApp.SetUserPreferenceToggle swPDFExportPrintHeaderFooter, [PdfPrintHeaderFooter]
        swApp.SetUserPreferenceToggle swPDFExportUseCurrentPrintLineWeights, [PdfUsePrinterLineWeights]
    ' IGES
    ElseIf LCase(ext) = ".igs" Then
        swApp.SetUserPreferenceToggle swIGESExportSolidAndSurface, [IgesExportSolidSurface]
        swApp.SetUserPreferenceIntegerValue swIGESRepresentation, [IgesRepresentation]
        swApp.SetUserPreferenceToggle swIGESExportAsWireframe, [IgesExportWireframe]
        swApp.SetUserPreferenceIntegerValue swIGESCurveRepresentation, [IgesCurveRepresentation]
        swApp.SetUserPreferenceIntegerValue swIGESSystem, [IgesSystem]
        swApp.SetUserPreferenceToggle swIGESExportFreeCurves, [IgesExportFreeCurves]
        swApp.SetUserPreferenceToggle swIGESExportSketchEntities, [IgesExportSketchEntities]
        swApp.SetUserPreferenceToggle swIGESHighTrimCurveAccuracy, [IgesHighCurveAccuracy]
        swApp.SetUserPreferenceToggle swIGESComponentsIntoOneFile, [IgesComponentsIntoOneFile]
        swApp.SetUserPreferenceToggle swIGESFlattenAssemHierarchy, [IgesFlattenAssemblyHierarchy]
    ' ACIS
    ElseIf LCase(ext) = ".sat" Then
        swApp.SetUserPreferenceIntegerValue swAcisOutputGeometryPreference, [AcisGeometry]
        swApp.SetUserPreferenceIntegerValue swOutputVersion, [AcisVersion]
        swApp.SetUserPreferenceIntegerValue swAcisOutputUnits, [AcisOutputAsUnit]
    ' STEP
    ElseIf LCase(ext) = ".step" Then
        swApp.SetUserPreferenceIntegerValue swAcisOutputGeometryPreference, [StepGeometry]
        swApp.SetUserPreferenceIntegerValue swStepAP, [StepVersion]
    ' Parasolid
    ElseIf LCase(ext) = ".x_t" Or LCase(ext) = ".x_b" Then
        swApp.SetUserPreferenceIntegerValue swParasolidOutputVersion, [ParasolidVersion]
        swApp.SetUserPreferenceToggle swXTAssemSaveFormat, [ParasolidFlattenHierarchy]
    ' VRML
    ElseIf LCase(ext) = ".wrl" Then
        swApp.SetUserPreferenceIntegerValue swExportVrmlUnits, [VrmlOutputAsUnit]
        swApp.SetUserPreferenceToggle swExportVrmlAllComponentsInSingleFile, [VrmlSaveAssemblyAsOneFile]
    ' STL
    ElseIf LCase(ext) = ".stl" Then
        swApp.SetUserPreferenceToggle swSTLBinaryFormat, [StlOutputAs]
        swApp.SetUserPreferenceIntegerValue swExportStlUnits, [StlOutputAsUnit]
        swApp.SetUserPreferenceIntegerValue swSTLQuality, [StlQuality]
        swApp.SetUserPreferenceToggle swSTLDontTranslateToPositive, [StlDontTranslatePositive]
        swApp.SetUserPreferenceToggle swSTLComponentsIntoOneFile, [StlComponentsIntoOneFile]
        swApp.SetUserPreferenceToggle swSTLCheckForInterference, [StlCheckForInterferences]
    ' TIF or PSD
    ElseIf LCase(ext) = ".tif" Or LCase(ext) = ".psd" Then
        swApp.SetUserPreferenceIntegerValue swTiffImageType, [TifImageType]
        swApp.SetUserPreferenceIntegerValue swTiffCompressionScheme, [TifCompressionScheme]
    ' eDrawings
    ElseIf LCase(ext) = ".eprt" Or LCase(ext) = ".easm" Or LCase(ext) = ".edrw" Then
        swApp.SetUserPreferenceToggle swEDrawingsOkayToMeasure, [EdrwOkayToMeasure]
        swApp.SetUserPreferenceToggle swEDrawingsExportSTLOkay, [EdrwAllowExportOfSTL]
        swApp.SetUserPreferenceToggle swEDrawingsSaveShadedDataInDrawings, [EdrwSaveShadedData]
        swApp.SetUserPreferenceToggle swEDrawingsSaveBOM, [EdrwSaveBOM]
        swApp.SetUserPreferenceToggle swEDrawingsSaveAnimationOkay, [EdrwSaveMotionStudies]
        swApp.SetUserPreferenceToggle swEDrawingsSaveAnimationToAllConfigs, [EdrwSaveMotionStudiesToAllConfs]
        swApp.SetUserPreferenceToggle swEDrawingsSaveAnimationRecalculate, [EdrwRecalcMotionStudies]
Function GetFullFileName(convFileName, conf, i, itemCount)
    ' Configuration name may include backslash. Remove it since otherwise saving will
    ' fail due a missing directory
    conf = Replace(conf, "\", "")
    conf = Replace(conf, "/", "")
    finalFileName = Replace(convFileName, "<Configuration>", conf)
    ' If no configuration
    If finalFileName = convFileName And itemCount > 0 Then
        finalFileName = Left(convFileName, InStrRev(convFileName, ".") - 1) & "_" & i & Mid(convFileName, InStrRev(convFileName, "."))
    ' Remove illegal characters from filename
    finalFileName = Replace(finalFileName, "<", "")
    finalFileName = Replace(finalFileName, ">", "")
    finalFileName = Left(finalFileName, 2) + Replace(finalFileName, ":", "", 3) ' Don't start from begin since drive has :
    finalFileName = Replace(finalFileName, "*", "")
    finalFileName = Replace(finalFileName, "?", "")
    finalFileName = Replace(finalFileName, """", "")
    finalFileName = Replace(finalFileName, "|", "")
    GetFullFileName = finalFileName
End Function
Sub Convert(docFileName)
    ' Constants for some SolidWorks error/warning returns that may be encountered during a convert operation.
    Const swerr_InvalidFileExtension = 256   ' the file extension differs from the SW document type.
    Const swerr_SaveAsNotSupported = 4096    ' the options selected for this convert aren't supported, output may be incomplete.
    Const swwarn_MissingOLEObjects = 512     ' the document contains OLE objects and must be opened and converted in SolidWorks.
    ' Determine type of SolidWorks file based on file extension
    If LCase(Right(docFileName, 7)) = ".sldprt" Or LCase(Right(docFileName, 4)) = ".prt" Then
        docType = swDocPART
    ElseIf LCase(Right(docFileName, 7)) = ".sldasm" Or LCase(Right(docFileName, 4)) = ".asm" Then
        docType = swDocASSEMBLY
    ElseIf LCase(Right(docFileName, 7)) = ".slddrw" Or LCase(Right(docFileName, 4)) = ".drw" Then
        docType = swDocDRAWING
    Else
        docType = swDocNONE
         If bIsSupporterExtension(Mid(docFileName, InStrRev(docFileName, ".") + 1)) = False Then
             Log "The file extension '" & Mid(docFileName, InStrRev(docFileName, ".") + 1) & "' is not supported."
             Exit Sub
    ' Open document
    If docType = swDocNONE Then
        Set swModel = swApp.LoadFile4(docFileName, "", Nothing, errors)
        docType = swModel.GetType
    Else
        Set swDocSpecification = swApp.GetOpenDocSpec(docFileName)
        swDocSpecification.DocumentType = docType
        swDocSpecification.ReadOnly = True
        swDocSpecification.Silent = True
        swDocSpecification.ConfigurationName = ""
       swDocSpecification.DisplayState = ""
        Set swModel = swApp.OpenDoc7(swDocSpecification)
        errors = swDocSpecification.Error
       ' Set swModel = swApp.OpenDoc6(docFileName, docType, swOpenDocOptions_Silent Or swOpenDocOptions_ReadOnly, "", errors, warnings)
    If errors = swFutureVersion Then
        Log "Document '" & docFileName & "' is future version."
        Exit Sub
    ' Load failed?
    If swModel Is Nothing Then
        Log "Method call ModelDoc2::OpenDoc7 for document '" & docFileName & "' failed. Error code " & errors & " returned."
        Exit Sub
    If Val(Left(swApp.RevisionNumber, 2)) >= 18 Then
      swApp.Frame.KeepInVisible = True
    swApp.ActivateDoc2 docFileName, True, errors
    modelPath = swModel.GetPathName()
    modelFileName = Mid(modelPath, InStrRev(modelPath, "\") + 1)
    modelFileName = Left(modelFileName, InStrRev(modelFileName, ".") - 1)
    modelExtension = Mid(modelPath, InStrRev(modelPath, ".") + 1)
    ' Build destination filenames
    convFileName = "[OutputPath]"
    Dim convFileName2 As String
    convFileName2 = "[OutputPath2]"
    Dim convFilePath2 As String
    Dim convFileNameTemp2 As String
    Dim bSecondOutput As Boolean
    bSecondOutput = False
    If (Len(convFileName2) > 0) Then
        bSecondOutput = True
    ext = GetExtension(docType, "[FileFormat]")
    convFileName = Replace(convFileName, "<Filename>", modelFileName)
    convFileName = Replace(convFileName, "<Extension>", modelExtension)
    convFilePath = Left(convFileName, InStrRev(convFileName, "\"))
    CreatePath convFilePath
    convFileName = convFileName & ext
    If bSecondOutput = True Then
        convFileName2 = Replace(convFileName2, "<Filename>", modelFileName)
        convFileName2 = Replace(convFileName2, "<Extension>", modelExtension)
        convFilePath2 = Left(convFileName2, InStrRev(convFileName2, "\"))
        CreatePath convFilePath2
        convFileName2 = convFileName2 & ext
    ' Set conversion options
    SetConversionOptions ext
    Set swExtension = swModel.Extension
    If docType = swDocDRAWING Then
        Dim vSheetNames As Variant
        Set swDrawing = swModel
        ' All sheets?
        If ([OutputSheets] And 2) = 2 Then
            vSheetNames = swDrawing.GetSheetNames
        ' Last active sheet?
        ElseIf ([OutputSheets] And 4) = 4 Then
            ReDim vSheetNames(0 to 0) As Variant
            vSheetNames(0) = swDrawing.GetCurrentSheet.GetName()
        ' Named sheet
        ElseIf ([OutputSheets] And 8) = 8 Then
            Dim vSheetNamesTemp As Variant
            vSheetNamesTemp = swDrawing.GetSheetNames
            removed = 0
            For i = 0 To UBound(vSheetNamesTemp)
                vSheetNamesTemp(i-removed) = vSheetNamesTemp(i)
                sheetName = vSheetNamesTemp(i)
                If Not sheetName Like "[NamedSheet]" Then
                    removed = removed + 1
                EndIf
            Next i
            If (UBound(vSheetNamesTemp) - removed) >= 0 Then
                ReDim Preserve vSheetNamesTemp(0 To (UBound(vSheetNamesTemp) - removed))
                vSheetNames = vSheetNamesTemp
        If Not IsEmpty(vSheetNames) Then
            ' Save sheets one per file
            If ([FileSheets] And 4) = 4 Then
                For i = 0 To UBound(vSheetNames)
                    Dim varSheetName        As Variant
                    swDrawing.ActivateSheet vSheetNames(i)
                    convFileNameTemp = GetFullFileName(convFileName, vSheetNames(i), i, UBound(vSheetNames))
                        Set swPDFExport = swApp.GetExportFileData(1)
                        varSheetName = vSheetNames(i)
                        swPDFExport.SetSheets swExportData_ExportSpecifiedSheets, varSheetName
                    ElseIf LCase(ext) = ".edrw" Then
                        swApp.SetUserPreferenceIntegerValue swEdrawingsSaveAsSelectionOption, swEdrawingSaveActive
                    ' Convert the document
                    Success = swExtension.SaveAs(convFileNameTemp, swSaveAsCurrentVersion, swSaveAsOptions_Silent, swPDFExport, errors, warnings)
                    ' Save failed?
                    If Success = False Then
                        If errors = swerr_InvalidFileExtension Then
                            Log "The file '" & docFileName & "' and sheet '" &  vSheetNames(i) & "' can't be converted to the file extension '" & ext & "'."
                        Else
                            Log "Method call ModelDocExtension::SaveAs for document '" & convFileNameTemp & "' and sheet '" & vSheetNames(i) & "' failed. Error code " & errors & " returned."
                            If (((errors And swerr_SaveAsNotSupported) <> 0) And ((warnings And swwarn_MissingOLEObjects) <> 0)) Then
                               Log "This document contains OLE objects. Such objects can't be converted outside of SolidWorks. Please open the document and perform the conversion from SolidWorks."
                        End if
                        convFileNameTemp2 = GetFullFileName(convFileName2, vSheetNames(i), i, UBound(vSheetNames))
                        Success = swExtension.SaveAs(convFileNameTemp2, swSaveAsCurrentVersion, swSaveAsOptions_Silent, swPDFExport, errors, warnings)
                        ' Save failed?
                            Else
                                Log "Method call ModelDocExtension::SaveAs for document '" & convFileNameTemp2 & "' and sheet '" & vSheetNames(i) & "' failed. Error code " & errors & " returned."
                            End if
                Next i
            ' Save PDF sheets to one file
            ElseIf ([FileSheets] And 2) = 2 Then
                    Set swPDFExport = swApp.GetExportFileData(swExportPdfData)
                    swPDFExport.SetSheets swExportData_ExportSpecifiedSheets, vSheetNames
                    If ([OutputSheets] And 2) = 2 Then ' All sheets?
                        swApp.SetUserPreferenceIntegerValue swEdrawingsSaveAsSelectionOption, swEdrawingSaveAll
                    ElseIf ([OutputSheets] And 4) = 4 Then ' Last active sheet?
                    ElseIf ([OutputSheets] And 8) = 8 Then ' Named sheet
                        swApp.SetUserPreferenceIntegerValue swEdrawingsSaveAsSelectionOption, swEdrawingSaveSelected
                        selectedSheets = Join(vSheetNames, vbLf)
                        swApp.SetUserPreferenceStringListValue swEmodelSelectionList, Trim(selectedSheets)
                convFileNameTemp = GetFullFileName(convFileName, "All", 0, 0)
                ' Save failed?
                    Log "Method call ModelDocExtension::SaveAs for document '" & convFileNameTemp & "' failed. Error code " & errors & " returned."
                    convFileNameTemp2 = GetFullFileName(convFileName2, "All", 0, 0)
                    ' Save failed?
                        Log "Method call ModelDocExtension::SaveAs for document '" & convFileNameTemp2 & "' failed. Error code " & errors & " returned."
        Else
            Log "Document '" & docFileName & "' didn't contain any sheets named '[NamedSheet]'."
    Else
        Dim vConfNames As Variant
        Set swConfMgr = swModel.ConfigurationManager
        ' All configurations?
        If ([OutputConfs] And 2) = 2 Then
            vConfNames = swModel.GetConfigurationNames
        ' Last active conf?
        ElseIf ([OutputConfs] And 4) = 4 Then
            ReDim vConfNames(0 to 0) As Variant
            vConfNames(0) = swConfMgr.ActiveConfiguration.Name
        ' Named confs
        ElseIf ([OutputConfs] And 8) = 8 Then
            Dim vConfNamesTemp As Variant
            vConfNamesTemp = swModel.GetConfigurationNames
            removed = 0
            For i = 0 To UBound(vConfNamesTemp)
                vConfNamesTemp(i-removed) = vConfNamesTemp(i)
                confName = vConfNamesTemp(i)
                If Not confName Like "[NamedConf]" Then
                EndIf
            Next i
            If (UBound(vConfNamesTemp) - removed) >= 0 Then
                ReDim Preserve vConfNamesTemp(0 To (UBound(vConfNamesTemp) - removed))
                vConfNames = vConfNamesTemp
        If Not IsEmpty(vConfNames) Then
            If ([FileConfs] And 4) = 4 Then
                ' Save configurations
                For i = 0 To UBound(vConfNames)
                    swModel.ShowConfiguration vConfNames(i)
                    convFileNameTemp = GetFullFileName(convFileName, vConfNames(i), i, UBound(vConfNames))
                    Success = swExtension.SaveAs(convFileNameTemp, swSaveAsCurrentVersion, swSaveAsOptions_Silent, Nothing, errors, warnings)
                    ' Save failed?
                            Log "The file '" & docFileName & "' and configuration '" & vConfNames(i) & "' can't be converted to the file extension '" & ext & "'."
                        Else
                            Log "Method call ModelDocExtension::SaveAs for document '" & convFileNameTemp & "' and configuration '" & vConfNames(i) & "' failed. Error code " & errors & " returned."
                        convFileNameTemp2 = GetFullFileName(convFileName2, vConfNames(i), i, UBound(vConfNames))
                        Success = swExtension.SaveAs(convFileNameTemp2, swSaveAsCurrentVersion, swSaveAsOptions_Silent, Nothing, errors, warnings)
                        ' Save failed?
                            Else
                                Log "Method call ModelDocExtension::SaveAs for document '" & convFileNameTemp2 & "' and configuration '" & vConfNames(i) & "' failed. Error code " & errors & " returned."
                                Log "warnings1 = " & warnings
                Next i
            ElseIf ([FileConfs] And 2) = 2 Then
                If LCase(ext) = ".eprt" Or LCase(ext) = ".easm" Then
                    If ([OutputConfs] And 2) = 2 Then ' All confs?
                    ElseIf ([OutputConfs] And 4) = 4 Then ' Last active conf?
                    ElseIf ([OutputConfs] And 8) = 8 Then ' Named confs
                        selectedConfs = Join(vConfNames, vbLf)
                        swApp.SetUserPreferenceStringListValue swEmodelSelectionList, Trim(selectedConfs)
                ' Save failed?
                    ' Save failed?
        Else
            Log "Document '" & docFileName & "' didn't contain any configurations named '[NamedConf]'."
    KillHolder convFilePath
    KillHolder convFilePath2
    ' Process virtual components
    If docType = swDocASSEMBLY Then
        Dim vComponents As Variant
        Set swAssembly = swModel
        vComponents = swAssembly.GetComponents(True)
        If Not IsEmpty(vComponents) Then
          For i = 0 To UBound(vComponents)
              Dim swComponent As SldWorks.Component2
              Set swComponent = vComponents(i)
              If swComponent.IsVirtual Then
                  Convert swComponent.GetPathName()
          Next i
    ' Close document
    swApp.QuitDoc swModel.GetTitle
Function bIsSupporterExtension(oExtension) As Boolean
    If docFileName = "prt" Then
       bIsSupporterExtension = True
    ElseIf docFileName = "asm" Then
    ElseIf docFileName = "drw" Then
    ElseIf docFileName = "dxf" Then
    ElseIf docFileName = "dwg" Then
    ElseIf docFileName = "psd" Then
    ElseIf docFileName = "ai" Then
    ElseIf docFileName = "lfp" Then
    ElseIf docFileName = "sldlfp" Then
    ElseIf docFileName = "prtdot" Then
    ElseIf docFileName = "asmdot" Then
    ElseIf docFileName = "drwdot" Then
    ElseIf docFileName = "x_t" Then
    ElseIf docFileName = "x_b" Then
    ElseIf docFileName = "xmt_txt" Then
    ElseIf docFileName = "xmt_bin" Then
    ElseIf docFileName = "igs" Then
    ElseIf docFileName = "iges" Then
    ElseIf docFileName = "step" Then
    ElseIf docFileName = "stp" Then
    ElseIf docFileName = "sat" Then
    ElseIf docFileName = "vda" Then
    ElseIf docFileName = "wrl" Then
    ElseIf docFileName = "stl" Then
    ElseIf docFileName = "cgr" Then
    ElseIf docFileName = "xpr" Then
    ElseIf docFileName = "xas" Then
    ElseIf docFileName = "ipt" Then
    ElseIf docFileName = "iam" Then
    ElseIf docFileName = "par" Then
    ElseIf docFileName = "psm" Then
    ElseIf docFileName = "ckd" Then
    ElseIf docFileName = "emn" Then
    ElseIf docFileName = "brd" Then
    ElseIf docFileName = "bdf" Then
    ElseIf docFileName = "idb" Then
    ElseIf docFileName = "3dm" Then
    Else
        bIsSupporterExtension = False
End Function
Sub Applystamp()
    Dim swSktManager As SldWorks.SketchManager
    Dim swMathUtility As SldWorks.MathUtility
    Dim swMathPoint As SldWorks.MathPoint
    Dim PointCoords(2) As Double
    Dim swSktBlkDef As SldWorks.SketchBlockDefinition
    Dim currentsheet As Sheet
    Dim Width As Double
    Dim Height As Double
    Dim sheetsize As Integer
    Dim value As Integer
    Dim vSheetProperties As Variant
    Dim scale1 As Double
    Dim scale2 As Double
    Dim PI As Double
    Set swDrawing = swApp.ActiveDoc
    Set swSketchManager = swDrawing.SketchManager
    Set swMathUtility = swApp.GetMathUtility
    ' Set PI
    PI = 4 * Atn(1)
    ' Get sheet size
    Set currentsheet = swDrawing.GetCurrentSheet
    value = currentsheet.GetSize(Width, Height)
    ' Get sheet scale
    vSheetProperties = currentsheet.GetProperties
    scale1 = vSheetProperties(2)
    scale2 = vSheetProperties(3)
    If Width > Height Then
        PointCoords(0) = (Width - 0.2) * scale2 / scale1
        PointCoords(1) = (0.25 * Height) * scale2 / scale1
        Set swMathPoint = swMathUtility.CreatePoint(PointCoords)
        Set swSktBlkDef = swSketchManager.MakeSketchBlockFromFile(swMathPoint, "C:\EPDM\Consultec Library\Blocks\Issue Tags\Block-Issued.Uncontrolled.Document.SLDBLK", False, Width / 30, PI / 6)
    Else
        PointCoords(0) = (0.25 * Width) * scale2 / scale1
        PointCoords(1) = (0.2) * scale2 / scale1
        Set swSktBlkDef = swSketchManager.MakeSketchBlockFromFile(swMathPoint, "C:\EPDM\Consultec Library\Blocks\Issue Tags\Block-Issued.Uncontrolled.Document.SLDBLK", False, Height / 30, 5 * PI / 3)
    On Error GoTo Fail:
    docFileName = "<Filepath>"
    ' Get SW interface object
    Applystamp
    Convert docFileName
    Exit Sub
Fail:
    Log "Error while converting file '" & docFileName & "': " & vbCrLf & _
        "An unexpected error occurred while executing the generated script. Script syntax error?" & vbCrLf & _
        "Error number: " & Err.Number & vbCrLf & _
        "Error description: '" & Err.Description & "'" & vbCrLf
I was able to determine (by commenting out and then uncommenting code in the Applystamp sub), that the issue comes from this line:
which is working fine when the macro is running on its own.
What I am wondering is:
  • Are there limitations to what can be added to the task code?
  • How are we supposed to batch run macros on files using EPDM tasks? Is it as simple as a code copy paste?
Any suggestion to solve that greatly appreciated.
