Macro to export clearance detection into excel
Question asked by David Wright on Dec 14, 2012
Latest reply on May 1, 2013 by David Wright
Hi guys, please forgive me if I'm posting this in the wrong thread, but I'd like to see if there is a command to put in a macro that will allow the interference detection tool to scan for a clearance of "x.xx" within an assembly. I work with electrical PCB's that contain 1000's of components and I for thermal reasons I try to get as close to the components as I can with the enclosures we use. (mitigating clearance issues of course.) I need to export the clearance verification report into an excel file. What I have so far is the following; VBA:
Private Sub LoadInterferencesComponentsIntoSpreadsheet()
    Set swModelDoc = swApp.ActiveDoc
    Set swAssemblyDoc = swModelDoc
    Set pIntMgr = swAssemblyDoc.InterferenceDetectionManager
    vint = pIntMgr.GetInterferenceCount
     vint = pIntMgr.TreatSubAssembliesAsComponents
    ws.Range("D2").Value = "NO. OF INTERFERENCES = " & vint
    ws.Range("D2").Font.ColorIndex = 3
    ws.Range("D2").ColumnWidth = 35
    vintvol = pIntMgr.GetInterferences
    For col = LBound(vintvol) To UBound(vintvol)
    compvol = (vintvol(col).Volume) * 61023.744094732
    ws.Cells((col + 3), "C").Value = compvol
    Next col
    For x = LBound(vintvol) To UBound(vintvol)
    comp = vintvol(x).Components
    n = comp(0).Name2
    m = comp(1).Name2
    ws.Cells((x + 3), "A").Value = n
    ws.Cells((x + 3), "B").Value = m
    Next x
    pIntMgr.Done
    sPathName = swModelDoc.GetPathName
    sPathName = Left(sPathName, Len(sPathName) - 6)
    sPathName = sPathName + "xls"
    ws.SaveAs sPathName ' The excel file will be saved in the same folder as the Assembly
The problem with this code is it uses the InterferenceDetectionManager and I can't figure out a way to make it detect parts that are closer than "x.xx" apart.
Any ideas?
