I have many custom weldment profiles set up, all of which are Aluminum.
I would like to have the structural body material be set to Aluminum by default for these profiles.
I figured I would go to the weldment profile SLDLFP file, and set the material to Aluminum there.
However when I tried creating a weldment part using the profile with the material set to aluminum, the material for the body created with the custom profile was still not set.
Is there any way to set a default material for the bodies created from a custom weldment profile?
Thanks.
The best way would be to create a new part template and give it a name Weldment -AL. Now whenever you need to design parts with custom profiles the use this template and you should be good to go.
