hello,
i have made a frame using a weldment,
now i want to view the dimensions in a cutting list apart from eachother so i can use these dimensions in excel to perform calculations.
so i want to get the width, height and wallthickness from tubes next to eachother.
is this possible? because i can only choose: length, angle 1 and 2, unit of measurement, description and material.
or should i use an other table for this?
grtz, NV
I know, but the problem is that the width, height and wallthickness is all viewed under description.
What i want is those three apart from eachother.
Edit the custom properties of your weldment profile and change as per requirements. Finally when you do the cut list, they'll come separate.
