Hii,
I would like To Know How Can I Work Out an Impact Test In solid Works???.. Can Anyone help Out
Hii,
Thank You For your Reply Sir... And Your Assumption is Absolutely Correct I want to know how to set this test up.. And another Test I require is Tortion Test.. It would Be really Helpful If you Can Tell Me the Procedure For Conducting These Tests.. And One More Thing These Tests Are for a Go-kart Chassis..
Hi Rohit; I assume you mean how to set it up? It asks for either 1) impact velocity, or 2) height above the ground. Another setup parameter is to choose a direction for impact, a direction for gravity, and how many microseconds to integrate post impact (I believe it defaults to 25 microseconds). Warning: the saving of results at time steps can cause a HUGE amount of data to be written to disk, so there is an option to limit the output (such as every other step, for example). Hope that helps. - Tony
